![]() Join Date: Nov 2002
'67 Ignition Switch Housing
I just bought a '67 chrome ignition switch housing. PO set up the ignition switch as an "outie" instead of the stock "innie". I want it stock looking so I got the switch. Goes on fine, but I obviously need some typs of spacer behind the dash pushing the switch back. As it is, it flops forward out of the instrument panel.... So I had to put it back together as PO had it(for now).
I do not know if ITruck is early or late '67. The ignition switch retainer bezel I got is for the early '67 truck. Are the ignition switch spacers the same for both? I haven't seen a spacer marked "early '67", only late. Does this mean only the late '67's needed the spacer and I bought the wrong part? As usual, thanks for any information y'all might provide.
"Truck" '67 small window '79 350 .030 over, LT1 "clone" |
a pic might help (give you more responces), but i think they both take spacers. I believe the one you need is the shorter one.
70 chev c10 swb fleet 72 grill, sb 400, 2/4 drop. 68 chev c10 swb fleet Early classic 4/6 drop with 4wheel disc brakes 9"rear 67-8 buckets tilt and A/C Classic GM Truck Club of Washington . |
the 67 switch spacer is different than the 68-72 spacer. I have not run into a difference between an eary and late 67. I probably have a used one. I can check when I get to the shop tomorrow if interested.
Thanks,Bill
atheystruck@comcast.net 67 1/2 ton 4wd custom cab 72 1/2 ton 4wd super cheyenne 71 1/2 BB super cheyenne shortbed |
Most definately
Yes, I'm very interested. Thanks for any help. Don't know if you remember me - I got all my window and door rubber replacement from you about a year ago.Sure helps quiet the rattles.
Sorry, I have looked and don't have any left.
I appreciate your looking for it.
