![]() Join Date: Mar 2004
66 suspension swap.
Hi,
I was wondering if anyone could tell me if you can swap out the entire front suspension from a 76 half ton to a 66 half ton? I have a 66 short box 1/2 ton pickup and a 76 half ton parts truck. I would like to use the spindles and rotors to get disc brakes, but not sure what I would need to do to accomplish this task. Also can I use the power booster off of the 76? How about the steering box....the 76 is a two wheel drive pickup? Thanks in advance for the help. Kevin |
cmon guys!
cmon guys, someone help me out here!
Watch out for your cornhole !
![]() Join Date: Jun 2003
Your good, but you will need to do a little mod to make the steering box work. There is currently a power steering thread around here detailing how to dimple the frame for box clearance.
The crossmember swap has been done gobs of times. It's pretty much a slam dunk, requiring only 2 bolt holes to be slightly enlongated. All of the rest of the bolts line straight up. I do not know about the brake booster swap.
///Relaxed Atmosphere
I have doen this
I swapped all my 64 front end outwith all ne updated parts that you are mentioning. The power stearing box reauires a modified brakect to mount it tot he frame. I belwive Brothers or some like that has a bracket you can buy for this. The brake booster will require you to drill some holes to get it to mount. All in all it is a fairly simple swap/ When I did mine I went ahead and added drop spindles and air ride.
72 Suburban 64 Chevy short fleet 04 Chevy Colorado Sport Reg Cab 2012 Chevy Avalanche 2003 Chevy S10 Blazer Xtreme http://www.hubgarage.com/mygarage/RA_Jeff 64 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=295915 |
