Old 03-15-2004, 05:45 PM   #1
smitty62
smitty62's Avatar
Various lowering questions
Is it better to lower a rear using 2" lowering blocks and 2" lowering springs for a 4" drop---OR use 4" lowering springs only?
Also, will my '68 stepside "bottom out" easily with a 4" drop or should I use a "C" notch? I lowered my '96 P/U 4" in the rear and it bottomed--not pleasant at all Had to take 2" back out of it to ride right. Thanks!
Stepsides look like real trucks!
Smitty
smitty62 is offline   Reply With Quote
Old 03-15-2004, 07:13 PM   #2
SCOTI
SCOTI's Avatar
Re: Various lowering questions
2" springs & 2" blocks would give the best ride compromise.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-15-2004, 07:22 PM   #3
SCOTI
SCOTI's Avatar
.... will my '68 stepside "bottom out" easily with a 4" drop or should I use a "C" notch? I lowered my '96 P/U 4" in the rear and it bottomed--not pleasant at all Had to take 2" back out of it to ride right....
With a 4" drop, a c-section is not necessary. The later model frames (88-up) do need the c-section because they don't kick up like the earlier model frames. Not having the kick up brings the rear axle tubes that much closer to the frame when lowering.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-23-2004, 05:58 PM   #4
chevykid04
4 speed, hurst shiftin
chevykid04's Avatar
i thought c sections were performed on pregnant woman??
Shane
1970 Chevy C10
chevykid04 is offline   Reply With Quote
Old 03-23-2004, 08:23 PM   #5
smitty62
smitty62's Avatar
Smitty
