03-16-2004, 12:05 AM | #1 |
GO VOLS!
new process 205 transfer case
Does anyone know if a '76 K10 used the NP 205?
http://1972blazer.shutterfly.com/<= blazer build pics It's called golf because all the other four letter words were taken. It's easier to ask for forgiveness than for permission. |
03-16-2004, 01:22 AM | #2 |
Its posible they used one but most likely only if it had a stick in it or was ordered that way.
03-16-2004, 01:37 AM | #3 |
like chevy blazer guy said-if it has the "granny gear" 4-speed it's probably a 205.if it's an auto it's more than likely a 203.
crawl under it and see if it has a small cover with 3 bolt holes on the back.if it does it's a 205.you could go to advance adapters web site they have a picture of how to i.d a 205. |
03-16-2004, 01:29 PM | #4 |
GO VOLS!
Thanks! I think I've run across a TH350/NP205 Combo just down the street from me. Now, as for the cross member....my blazer has the original Dana 20 Transfer case, will I have to raise or lower the mounts for the NP205?
03-16-2004, 03:36 PM | #5 |
SKINNY TIRES RULE!
Your '72 has a dana 20? I thought they stopped using the Dana 20 in the K5's in '70. Anyway, a PO swapped the dana 20 in my blazer for a 203 (TH350/NP203). The cross member has blocks between it and the frame to drop the t-case about 2".
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
