Old 03-18-2004, 11:02 PM   #1
elmono
Driver's side is 3/4" lower than pass. side
I've replaced all of the springs w/ 2" Rough Country lift springs and I replaced the body mounts w/ new GM rubbers. The truck is still 3/4" lower on the driver's side. Has anyone experienced this? Thanks, Chad.
1985 GMC K1500 350 700r4 NP208 3.73
elmono is offline   Reply With Quote
Old 03-18-2004, 11:21 PM   #2
IoWnZa
Big Block Blazer
lol, my Pass. side is a little lower cause I just blew out a Rancho RS5000 for no known reason, so I got some real cheap shock on their now, and the rest of the RS5000's. I wasnt even wheeling, I was just driving down a road, not being rough on it or anything. they are 2 months old!
Anyways, that is my story.
For your issue, are you sittin in the truck when you notice it is lower?
[1985 Chevrolet K5 Blazer][454BBC][TH400][NP241][Dana 44][GM 12 Bolt w/ Eaton LSD][Hedman HTC Hedders][Dual 2.5" Stainless Steel Exhaust][Hedman Turbo Muffler's][Dual Spal's 14" Electric Fan's][32x11.50R15 BF Goodrich All Terrain TA KO's on 15x8 Rallys]
IoWnZa is offline   Reply With Quote
Old 03-19-2004, 12:21 AM   #3
elmono
Forgot to mention that I've got dual tanks. No, I'm not in the truck when I notice the lean. Did your shock blowout cause your truck to lean? I hadn't even thought about the shocks, thanks for your help.
Old 03-19-2004, 02:40 AM   #4
Scrub
Collector of rusty Items
Scrub's Avatar
There was a post about the same problem a few months back. The guy did about everything and never did solve the problem. I think he finally sandbagged the right side.
I wonder if you should weigh both sides of your truck independantly to see if both sides are even and then sandbag it.
I always wondered why the front left spring has a piece that keeps the shackle from going back too far and special pieces across the front to contain the spring. It seems like they where expecting the left front spring to break.
Good luck
Scrub
Sisters, Oregon - Home of the Sisters Rodeo.
70 GMC 1,000,000 + miles
72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub is offline   Reply With Quote
Old 03-19-2004, 06:55 AM   #5
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
swap front springs side to side. could be a mis-matched set. Are your cab mounts and frame supports straight? i.e. not bent or crushed a little?
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
