03-20-2004, 09:51 PM | #1 |
HMMMM Chevy
lifting a diesel
I am wanting to lift my '82 GMC which has a 6.2l diesel in it. I need a good set of front springs that are going to take the load. The diesel is about 300 lbs. heavier than a sbc I think. So I need a spring that will take the weight and give me a 4" lift. Anybody got any suggestions?
68 Chevy C10 swb(under construction) 82 GMC K1500 6.2l diesel (daily driver) 77 Chevy K30 frame (only thing left is axles and trans/transfer)______________________________ Mike |
03-24-2004, 11:49 AM | #2 |
user # 2756
Go with rough country springs they seem to have one of the highest spring rates. I also believe Rancho has high spring rates. Stay away from soft or ez ride springs. My 2" heavy duty tuff country springs netted about 3" of lift, you could try them (they have 2 and 4" HD springs).
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
03-24-2004, 11:35 PM | #3 |
you could probably just use the next size spring. ya know if its a half ton, use a 3/4 ton lift spring, if a 3/4 ton usea 1 ton leafs.
04-15-2004, 09:13 PM | #4 |
I have a '72 K10 that's getting a 454. I ordered a 4" lift kit from Superlift with Heavy Duty front springs designed specifically for a Big Block or Diesel truck. I bought mine on ebay from Davy1445.
