03-22-2004, 11:57 PM | #1 |
Rear gear ratios - how low can I go?
I have a series 3 posi and was wondering what my options were should I decide to change ratios.
Any info is appreciated. Thanks. |
03-23-2004, 12:06 AM | #2 |
With a series three you can go as low as 3.73, I believe. After that you need a series four.
Andy,Phx AZ '67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...) "23 C-Cab-sold '48 Ford 8N tractor(still working) '67 Scout(Now on the road) '70 MG B.-sold |
03-23-2004, 12:53 AM | #3 |
you can go to 4.56 with thicker gears made for a 3 series
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
03-23-2004, 01:37 AM | #4 |
With the correct case I believe you can go to a 5.38 ratio in a 12 bolt
03-23-2004, 01:49 AM | #5 |
Series 3---2:76 to 3:42
Stepsides look like real trucks! Smitty |
03-23-2004, 01:53 AM | #6 | |
03-23-2004, 02:38 AM | #7 | |
My son, my joy.
03-23-2004, 11:28 AM | #8 | |
03-23-2004, 11:31 AM | #9 | |
03-23-2004, 06:56 PM | #10 |
There are spacers available that will allow a 4 series gear to fit in the 3 series carrier and as stated you can also purchase the thicker gears for the three series. Pretty much the same idea just a different approach.
............................................................ 68 Chevy CST SWB w/LS1, carb & 700r4. Golden Anniversary clone with a few improvements. |
03-23-2004, 08:36 PM | #11 |
is there a way to check what the gear ratio is in the rear end without pulling the diff cover?
