Old 03-25-2004, 02:13 PM   #1
dubie
dubie's Avatar
Question Best Headers gasket out there??
What is the best type of gasket to use for sealing headers up to the head? Are some brandes better than others? recommendations?
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 03-25-2004, 02:15 PM   #2
Bobalouie
Fetzer Valve Technician
Bobalouie's Avatar
Percy's Dead Soft Aluminum
Bobalouie is offline   Reply With Quote
Old 03-25-2004, 03:00 PM   #3
strokenit
dont use any I havent ever they just get in the way and I have never had a set leak
strokenit is offline   Reply With Quote
Old 03-25-2004, 03:25 PM   #4
Dean
Dean's Avatar
I could see not putting gaskets on stock manifolds, but non on headers? I've never been that lucky.
I'd do a few engine warm ups and tighten when you install them.
Dean is offline   Reply With Quote
Old 03-25-2004, 03:26 PM   #5
Mudder
Mudder's Avatar
the metalic manifold gaskets
Mudder is offline   Reply With Quote
Old 03-25-2004, 03:31 PM   #6
Hotrod70C10
Low & Slow
Hotrod70C10's Avatar
I agree. I have had a set of them on my truck for over a year and haven't had a leak yet.
70' C-10 LWB Fleetside
4.5/6 drop
Hotrod70C10 is offline   Reply With Quote
Old 03-25-2004, 03:33 PM   #7
Mudder
Mudder's Avatar
and they are only 7 bucks or so..........you can start all the bolts then just drop them in place
Old 03-25-2004, 03:34 PM   #8
Yukon Jack
Yukon Jack's Avatar
I went with the Percy Deadsoft Aluminum gaskets for my 454 - course I haven't fired it yet, but they sure look like they ought to work excellent. Given they way the compress, I can't see how they could leak.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 03-25-2004, 03:51 PM   #9
67Fleetsidedream
Wiseass secured himself a BAN
67Fleetsidedream's Avatar
Plain ole header gasket. Just check the bolts everynow and then to make sure they are tight.
67Fleetsidedream is offline   Reply With Quote
Old 03-25-2004, 04:05 PM   #10
dubie
dubie's Avatar
the gaskets you would use for manilfolds wouldn't work....would they?
Old 03-25-2004, 04:06 PM   #11
Mudder
Mudder's Avatar
sure will
Old 03-25-2004, 04:25 PM   #12
dubie
dubie's Avatar
good, I have 2 sets of them kickin around
What about the studs? are they the same as well? if not, what length do I need for the headers
Old 03-25-2004, 04:27 PM   #13
J
J's Avatar
I was always told that manifold gaskets will burn up if used on headers. I cant verify this.
I use the metallic ones. No leaks, easy to install and cheap.
'72 C-10
'99 Silverado
'91 S-Dime
J is offline   Reply With Quote
Old 03-25-2004, 06:49 PM   #14
dubie
dubie's Avatar
TTT
Anyone know about bolt length for headers? are the bolts the same as factory manofolds
Old 03-25-2004, 07:14 PM   #15
Bowtie67
Bowtie67's Avatar
You should use header bolts, if you dont, you will have a tough time installing them. Some headers are real tight even with header bolts.
Bowtie67 is offline   Reply With Quote
Old 03-25-2004, 07:38 PM   #16
cableguy0
you need to use header bolts normally a new set of headers come with em. they are generally between 3/4 and 1 inch long and the normal 3/8 x 16 thread pitch. they have a smaller head on em
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 03-25-2004, 08:40 PM   #17
valk_ryder
Percy's Dead Soft Aluminum...
I bought a set of Summit's house brand $79 headers. The flanges were a little skimpy on material. I used the Percy's round port and it filled in the gaps from the crappy headers.
Autozone in the Oklahoma City area recently started stocking Percy's.
valk_ryder is offline   Reply With Quote
Old 03-25-2004, 08:50 PM   #18
67Fleetsidedream
They will burn up if you put the metal part of the gasket towards the head. The metal part is supposed be what touches the header. Header gets hotter than the head, so paper part goes on head.
Old 03-25-2004, 10:47 PM   #19
rage'nrat638
rage'nrat638's Avatar
3/4 INCH BOLTS ARE FOR STOCK CAST HEADS...
1 INCH BLOTS ARE FOR ALUM. HEADS....
I RECOMMEND STAGE 8 LOCKING BOLTS....
NEVER HAVE TO TIGHTEN.....
THE CHEAP PAPER GASKETS...LIKE TO STICK TO THE HEADS AND MANIFOLDS....
I SPENT MORE TIME TRYING TO SCRAPE THAT JUNK OFF...
BUY SOME GOOD ALUM./COPPER GASKETS..
OR USE THE STOCK GASKETS....BUT PUT THE METAL ON THE MANIFOLD SIDE....
rage'nrat638 is offline   Reply With Quote
Old 03-25-2004, 11:17 PM   #20
Bill72BB
Thats the Hillbilly way
Bill72BB's Avatar
Thumbs up
Percy's Dead soft worked for me ,..
BILL
Torrance Calif 90504
Member DUF Club
Member Old Farts Club
72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts
tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion.
" If I knew I was going to live this long I would have taken better care of myself "
Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER....
Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen ,
Bill72BB is offline   Reply With Quote
Old 03-26-2004, 01:08 AM   #21
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
fell pro manifold gaskets hold up fine. I have a set on mine thats been there for a couple years now, and no blow outs yet. I even removed one header when I dropped the tranny, I got mega cheap and reinstalled the same gaskets. (figured I may as well try) so far no problem.
Old 03-26-2004, 01:15 AM   #22
BurnoutNova
BurnoutNova's Avatar
the best way to prevent leaks is a good header flange.
i also used copper jegs gskets andthey dont leak
BurnoutNova is offline   Reply With Quote
Old 03-26-2004, 02:11 AM   #23
LudwigTheMad
LudwigTheMad's Avatar
used regular ones from the store, used copper ones and used what I think are the allum. kind
they all work if you install them corectly....
however it doesn't hurt to use a littlle (I stress a little..lots bolt down pressure you know) high temp silicone (red) on them..
(I know...the screwy guy silicones everything....
you can use the stock bolts...but may be hard to get at bolt head......I'd use a set of header bolts (you can usually get them in any parts store that caries at least minimal performance parts)
I use some high temp locktight on them...but check them when ever you check you oil to see if they are comming loose....I actually lost one and never knew it....no leak....(guess the silicon really worked huh?) bigger problem on allum. heads.
That's right, I'm back in the game again. No it's not pink.....
1972 Blue and White Suburban.
LudwigTheMad is offline   Reply With Quote
