Try spinnin 4 rear tars
I did a search and came up with some info. But I still have questions...
My '70 came with a prop valve (or is it called a distributor valve, I hear that they are somewhat different ![]() Will an aftermarket valve just be plumbed inline with the rear brakes, or is there something that replaces the stock unit all together (is tied to both front and rear)? If I do install one on the rear brake line, should I expect that I need to apply more pressure on the pedal to stop the truck (since I will cut pressure to the rear brakes but still have the same to the front)?! Thanks everybody!!!
SWEET7T 1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB |
just add a adjustable valve on the rear line under the hood...
keep your stock valve....adjust it to your perfered setting... |
