04-01-2004, 05:49 PM | #1 |
2A674 Tank Rat
Difference from '58 - '59 Chevys/GMC
Does anyone know how to tell the difference between a 1958 Chevy from a 1959? How about a gmc too?
'92 GMC Sierra, Sportside, 2wd, 350, Black '92 Chevy Silverado Extended Cab 4 x 4, Blue USAFR = 2A674 = Aircraft Fuel Systems Maintenance i.e. Tank Rat |
04-01-2004, 06:54 PM | #2 |
member #16
I can't think of any ,They must be twins. Im sure I will be corrected if wrong,but i think the grille, fenders, hood and emblems were the same. John
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
04-01-2004, 06:59 PM | #3 |
The 58 and 59's are the same. There are just small differences between the Chevy and GMC, mostly in the grille
here is our 58 GMC
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
04-01-2004, 07:01 PM | #4 |
This is a 59 Chevy. The only other difference is the GMC emblem on the hood
04-01-2004, 07:05 PM | #5 |
here's one in a stepside bed. The bullet back fleetside was only available in 58 and 59
04-01-2004, 07:15 PM | #6 |
grille,bumper guards, emblems, dash( guages and cab), engines, and some available options are different. The GMC's have a two piece dash instead of just a v-shaped one like the chevy's and used Pontiac v-8's and their own six cylinders. All these are different and specific to the GMC's. The 59 Chevy's are the same except for the hood and fender emblems, everything else is interchangable to the 58's.
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
04-01-2004, 08:03 PM | #7 |
2A674 Tank Rat
I noticed on the GMC Grill the parking lights/turn signals are more pointed on the outside end and would be somewhat oval except for when they meat the cross bar on dubies '58, but the '59's are more square. Also, the GMC has the hollow points on the bumper. Is that just an option thing from the original owner? And the cross bar is thicker on the '59s.
A guy near me has a 4 x 4 stepside, and I have wondered how to tell the years diff. Thanks for all the replies.
04-02-2004, 01:04 AM | #8 |
back in the day (pre '67) when Chevy and GMC came off of different assembly lines, GMC was supposed to be a better made truck.
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 |
08-01-2023, 06:13 PM | #9 |
Re: Difference from '58 - '59 Chevys/GMC
Bringing back an old thread for a few more questions for the experts …
Is there a Difference between the core support mounts on the 58 / 59 Chevy & GMC on the frame ? The Chevy & GMC seem to use the same Chevy sheet metal . So I assume the core support mounts would be the same . The 57 Chevy & GMC used totally different core supports and frame mounts . Correct me if I’m wrong please .
Glen & Jane's Rides ‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008 7 other cars & trucks , 5 trailers '56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020 ’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020 My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275 Last edited by G&R's57GMC; 08-03-2023 at 11:13 PM. |
08-02-2023, 09:10 PM | #10 | |
My Current Trucks: 1958 Apache BBW 4.8LS/4l60 "Lucky" Built By Me 1958 GMC BBW LS1/4l60 "The Kraken" Built By Delmo |
08-03-2023, 01:25 PM | #11 |
You see what you did, Glen? Now guys are here answering the OP's question from 19 years ago...
08-01-2023, 09:34 PM | #12 |
At the body shop.
The fender Spear is what I've been told.
" That didnt make it any newer " " Dont antique the equipment " |
08-02-2023, 09:33 PM | #13 |
Checking the Classic heartbeat site Wes has the radiator support listed as 58/59 as far as chevy goes. https://www.classicheartbeat.com/pro...port-assembly/
08-02-2023, 09:51 PM | #14 |
Borrowed from the net. Butterscotch is 58 and copper is 59 and no I didn't look up the real names of the colors.
08-02-2023, 10:13 PM | #15 |
58 and 59 GMC The roadside truck is the 59. Borrowed from the net photos with all creds to the photographers.
08-03-2023, 01:03 PM | #16 |
Most of it covered . Add that drivetrains are very different . GMC used their own 6 Cylinder engines and V-8 engines that were borrowed from Pontiac . GMC trucks also used Dana rear ends on the 1/2 ton trucks. For some reason GMC used a lot of phillips screws where Chevy would use a clutch head . Different deluxe heater box to compensate for the differences in the dash . Some of the GMC trucks would have a large pipe brace from the upper cowl to the frame . I have seen them mostly on the Napco trucks but also ran across one on a 3/4 ton two wheel drive .
08-03-2023, 11:20 PM | #17 |
Yah , they are so helpful . But I did get my answer about the core support mount on the 58 & 59 GMC & Chevy chassis .
Glen & Jane's Rides ‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008 7 other cars & trucks , 5 trailers '56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020 ’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020 My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275 |
