Progress = 0%
Rear cab trim rivet locations?
Can somebody give me measurements on where the trim rivets go on the back of the cab??? I originally planned on painting the truck a solid color and ground off the rivets. Now I’ve decided to go with a white roof and need to weld on some new rivets. Mainly I need the vertical distance, like from the bottom of the window seal (small back window) to the center of the trim, or from the body line (that is below the trim) up to the center of the trim (or both just to make sure!)
Thanks!
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
Just use some duct tape to put it back on....
We made Oklahoma a little after 3, Randy & his brother Bob & my old GMC... |
Progress = 0%
TTT
I measured two big window cabs. Measuring from the bottom edge of the back window, no gasket, I get 2 5/8" to 2 3/4" to the pin center. To lay it out go to the bottom of the drip rail on the door. Measure up 1/2" on both sides and run a string between the sides. That should give you the 2 5/8" 2 3/4" I measured. That's the best I can offer, no small window available. Make any sense?
Larry 72 Chevy SWB 4x4 71 Chevy SWB 4x4 My Work Truck "Don't confuse enthusiasm with capability" Last edited by ljbear; 04-02-2004 at 03:52 PM. |
Progress = 0%
Just to clarify, those measurements are to the center of the trim, correct?
Thanks for measuring that for me! Jason
Yep, that's to the center of the pin. The drip rail looks like it's the best reference I could use.
Larry 72 Chevy SWB 4x4 71 Chevy SWB 4x4 My Work Truck "Don't confuse enthusiasm with capability" |
