Wire question - brown wire going to proportioning valve
What is the brown wire going to the proportioning valve on my 72 with power brakes? I am installing a new Painless Wiring harness into the entire truck, and there is no mention of this wire in the manual.
72 C10 Cheyenne Super Full trim Factory tach dash A/C dash Factory tilt 350 / 350 power train - with Edelbrock components. |
It's the brake failure warning switch.
72 Cheyenne Super 4x4 SWB |
On the road
![]() ![]() Join Date: Jan 2004
That's for the brake light in your dash. Not sure of all the ins and outs, I guess if you lose pressure ( I don't know how much pressure it takes to operate ) the light comes on.
Mike |
It should go to the ignition switch, and then to the cluster I think.
I think it is triggered by a large differential between front and rear brakes.
![]() Join Date: Feb 2000
There is a toggle switch inside of the Prop. valve with a diaphram that is pushed to either side by a large difference in pressure on one side or the other it grounds the signal and turns the light on. Also a grounding Emer. brake switch can be tied in to the wire to let you know that your E brake is....not that any of us have ever drove anywhere with our E Brake on!!!
Yeah, mine came on when I had manual brakes right before they started going out on me (before the power brake swap). I was quite impressed that after 30 years it actually still worked.
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
More Cowbell....
After 35 years, mine actually came on last November. All of the fluid from the front half of the master cylinder had leaked out, and I fired it up and moved it outside the garage. When I hit the brake, it went to the floor and the light came on. I was like....Woh!
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
Wiseass secured himself a BAN
How do you check it to see if it still works?
Beer Power!!!!!!!!!!
To check if it still works, simply disconnect the wire from the valve.
I had to replace my prop valve because, I guess, the old one wore out. TIP: Your old proportioning valve makes an EXCELLENT trotline weight.
Rather be fishin' |
