![]() Join Date: May 2002
Equipment for cab-lifting
I'm nearing the point of lifting the cab off my truck and setting it on a dolly for rockers, floor, etc repair. Any suggestions for a safe, cheap method of lifting it? I don't normally have 4-5 guys with strong backs standing around, so I need a way I can do it myself. Wooden trestle, what? Any help from previous "cab-lifters" would be appreciated.
Stepsides look like real trucks! Smitty ![]() |
member #16
![]() Join Date: Dec 1999
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
...i used my cherry picker (engine hoist) the last time...had to stack some cement blocks and have my son stand on the other end though
Ken Lyons, Slippery rock pa 68 short step 327 t10 4 gear 72 2wd blazer project 70 lwb 305/700r driver 78 caprice project 02 cavalier D.D ( hate it!!) |
Last time I did it, I used a 2" rope looped thru twice, so 4 lines. I was worried about bending the top of the cab, so I left the doors on for a little extra support. Since all I was doing was rolling one frame out and rolling another in, I didn't waste a lot of time removing the front clip, either. It was no doubt very heavy, but it seemed to work. As far as standing underneth to sandblast the bottom of the cab, I would recomend having your affairs in order first.
The last time I lifted mine I bolted a wood 4x4 to the cab floor where the front bolts are to bolt the seat to. Be careful because the cab is top heavy & will flip ! My 4x4 was extra long on both sides so I had saw horses on both sides to hold it up. You could use steel pipe too .
Actually lifted a cab I bought from Bill's Truck Parts off of a trailer on Sunday. I used two 2"x6"x8' nailed together with three 15" cross pieces.
72 Chevy C10 (rust repaired, starting body work) 72 GMC 3/4ton 4x4 72 Chevy C20 Suburban 38 Ford Tudor Humpback Sedan (from the darkside ![]() 67 Pontiac Parisienne 55 Studebaker Commander 2dr Hardtop (Starliner) My Youtube channel with Video Updates! |
Here's a pic showing the lifting "ladder" I guess you could call it.
I built an a-frame to move mine
I want to thank everyone for their contributions to my question. My problem is not how to lift so much as it is what to lift with. Could use more ideas like Robo bot's "A" frame. I don't have a barn door to lift on. Thanks!
heres some more pics
How long are the longest (tallest) 4x4's--12' ?
12' is the size for the height and 10' wide
Navel Inspector
Robo_bot: Your Avatar is just to cool!
1948 Chevy Aerosedan GONE! I think. 1984 Cadillac Fleetwood Brougham Coupe WANTED 1967 IMPALA 1967 CST C10 Long Bed with a 283 |
#15 |
The cab really isn't all that heavy. About a month ago, four of us pulled the cab off of a member's '55 Chevy P/U and placed it on a dolly. It was quite easy and alot lighter than expected. You don't have to be a big guy to do the job, none of us were.
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers '66 C10 - The new hot rod '77 3+3 Dually - 12 valve 4wd conversion tow rig project '28 Ford 2 door sedan street rod RevLimit Offroad "Hang on beer, we can do this." |
