Old 04-05-2004, 01:07 PM   #1
terrym1
terrym1's Avatar
drop blocks
is this too much and what about the shock angle? I a little new at this, any oponions, thanks terrym1
terrym1 is offline   Reply With Quote
Old 04-05-2004, 01:13 PM   #2
terrym1
terrym1's Avatar
oops
oops
Old 04-05-2004, 01:35 PM   #3
SCOTI
SCOTI's Avatar
Yes... it's too much w/a 15" diameter wheel. If you have a flat, the u-bolt ends/nuts & the shock plate are below the 'scrub line' & they will drag the pavement.
While blow-outs aren't common, they do occur & these old trucks can be a handful to control.... now add to that mix one corner of the truck dragging the ground & you get a dangerous combination.
Your safest bet would be to only use that set-up w/larger diameter wheels so that no part of the suspension touches the ground in the event of a flat. As far as the shock angle, it doesn't change w/lowering blocks.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-05-2004, 02:55 PM   #4
terrym1
terrym1's Avatar
thanks scott that really helps
terrym1
Old 04-06-2004, 01:32 PM   #5
dubie
dubie's Avatar
Here is a pic from TXfirefighters truck with 2 " lowering blocks
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 04-06-2004, 08:28 PM   #6
BigDaddyCMU
You'd definitely be better off with some drop springs. Some people say the cheaper ones can't handle the weight, but can 35 year old ones handle it as well? Depending on how low you go, you may have to mess with the spring angle. Kits are out there, but from what I've seen, it's not too hard to make your own out of some square tubing.
BigDaddyCMU is offline   Reply With Quote
Old 04-07-2004, 08:55 AM   #7
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
My truck picture Dubie posted above, those are 17 inch wheels too, and the u-bolts still hang down too low.
Imagine what they would be like with 15 inch wheels.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 04-09-2004, 08:06 PM   #8
tomsC10R
tomsC10R's Avatar
I think that is way too low. In case of a blow out. But right now those are so low that I'd be woried about large "bumps" that the tire could possibly miss or even the cement parking things (I can't think of what they're called) if you backed over something and happen to miss it with the tire. If you wanna go real low, get some springs.
Tom
1968 C10 LWB. 402 BB, Holley MPI, 700R4. 4wheel Hydroboost Disk Brakes.
tomsC10R is offline   Reply With Quote
Old 04-18-2004, 11:14 AM   #9
theo70
COMING SOON...
theo70's Avatar
Let me tell you what a dumb kid I was. In the minitruckin' 80's, I stacked a 4" block onto another 2" block for a 6" drop. I had to have custom u-bolts made, and they hung down so low, I had to hacksaw several inches off. At cruise spots, I had to be lifted off of every speed bump, but hey--I looked good.
theo70 is offline   Reply With Quote
