![]() ![]() ![]() love the site thanks for your help steppside69 |
Senior Moment
![]() Join Date: Mar 2002
Any chance you could get some pic's so we could get a better idea of what you’re talking about?? Something doesn't sound right
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
i dont know if you can put the tranny crossmember in backwards or not! dont have a camera so i dont have any pics to have a good visual. are there different crossmembers (tranny) for different year trucks (67-72) or are they all the same? if i try to put the reducers on the headers the pipe is right dead in the middle of the crossmember. the header on the driver side seems alot lower than the passenger side. does this sound right?
the passenger side is higer by 2 inches. that is where i have the problem ![]() |
Now are your referring to the member that holds up the rear of the transmission or up front near the bell house? The 3 speed tranny mounted up front near the bell house and the tail hung in the air. The auto will have the crossmember under tail of the tranny. Hope that helps...
ok- now this may sound a little strange, but is your motor mounted in the correct position for a small block?
(my motor is mounted incorrectly, and thus headers wont fit on my engine).... just an idea..... ![]()
68 C10 Red Step 350 my first child & main focus 58 3200 Apache LWB Step the upcoming project |
the crossmember is under the tail of the tranny.
i did have to move the motor forward because it had originally a 6 cylinder and the motor was to close to the cab. so i went to a local junk yard and got the right frame mounts. the motor is in the right place for a v8.the passenger side header is the problem, it sets to close to the collecter. thank you ![]() |
