Old 04-08-2004, 06:44 PM   #1
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Question Damn Newbie's
I GOT A NEWBIE QUESTION, WHAT IS INVOLVED IN PUTTING A
BIG BLOCK INTO MY 72 K5? I HAVE HEARD PEOPLE TALK ABOUT
TOWERS? IS THAT SOMETHING TO DO WITH MOTOR MOUNTS?
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Big Piggy: "Goliath" 07 Kodiak C4500
Lil Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 04-08-2004, 08:46 PM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
yep!
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 04-09-2004, 09:10 AM   #3
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
SO, DOES THAT MEAN I NEED TOWERS, I'M ASSUMING THE SB
SET-UP WILL NOT WORK, DO YOU HAVE TO USE SHORTY HDR'S
Old 04-10-2004, 01:07 AM   #4
72bigblock4wd
If you can find a set, the BB towers from a 2wd truck will work, I don't know if anyone sells new ones. The other thing you can do is use the Big Block towers from a 73-87 truck, you will just need ot make a spacer for the top of the frame, but it does work.
72bigblock4wd is offline   Reply With Quote
Old 04-10-2004, 11:06 AM   #5
Yukon Jack
Yukon Jack's Avatar
There is some info on the 2 pages at this link on put a 454 in my 69 K20.
http://www.myoldtruck.com/modules.ph...howpage&pid=12
Let me know if you have specific questions. I know a guy who is right in the middle of trying to do the 73-87 towers method, he is having some difficulty. I was pleasantly surprised how easy the engine went in course I still haven't dropped the body yet - something about a slow body shop holding me up.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 04-10-2004, 04:59 PM   #6
72bigblock4wd
My dad put a 366 Big Block in a '72 C20 that he has for towing stuff. He used the 73-87 towers and had no problems, he used a regular open-end lug nut for a spacer on the top of the frame. Personally, I would use something a little more substantial than a lug nut, but it will work.
Old 04-10-2004, 06:00 PM   #7
1972C10
1972C10's Avatar
I have a set of the factory 73-87 big block towers there is a difference between them I went from bb to sb in an 85 3/4 ton and i got differnt towers, From a Small block truck ,,
Tryed to sell the big block towers on the 73-87 parts forum and i got jumped on sayin i was tryin to rook people and there was no such thing.
After reading this i may hold on to them for if i ever go BBC in my 72
1972C10 is offline   Reply With Quote
Old 04-10-2004, 10:53 PM   #8
orangeuavol
GO VOLS!
orangeuavol's Avatar
My 402BB will fit the existing SB towers in my '72 K5. We test fit it before we removed the body and it fit like a glove...with the exception of some firewall messaging. But I can't use headers. I'll find the link where I posted pics and post it here.
http://1972blazer.shutterfly.com/<= blazer build pics
It's called golf because all the other four letter words were taken.
It's easier to ask for forgiveness than for permission.
orangeuavol is offline   Reply With Quote
Old 04-10-2004, 10:58 PM   #9
orangeuavol
GO VOLS!
here's the link. The BB pics are down near the bottom.
http://67-72chevytrucks.com/vboard/s...threadid=95929
Old 04-12-2004, 02:48 AM   #10
454_72_4X4
454_72_4X4's Avatar
Hey orangeuavol,
Nice pics BTW.
I have basically the same setup as you, (72 C20 4X4 4 speed), and have been running a 402 for a few years. I'm in the process of installing a 454 and am having a hard time locating a left side exhaust manifold. (The one I had on the 402 came off in 3 pieces!)
Do you have any other pics or casting number of your left manifold? The one I used is completely different than yours.
Have you checked to see if it will clear the clutch linkage?
How are you going to run your clutch linkage? (If you're gonna be running a manual trans).
72 C20 4X4 454 4 speed
89 Trans Am (was) 305 TPI 700r4
93 C1500 2wd Extended cab 350 700r4
98 Sonoma (TPI outa the Trans Am)
03 Yamaha 660 Raptor
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
454_72_4X4 is offline   Reply With Quote
Old 04-12-2004, 12:35 PM   #11
orangeuavol
GO VOLS!
The casting numbers have all been ground off. I believe the exhaust manifolds are out of a '72 Monte Carlo. I will be putting in an automatic tranny, don't have the patience to teach the wife to drive a manual.
