COMING SOON...
HELP bleeder kits
Is the HELP m/c bleeder kits designed to do one reservoir at a time, or do you cut the one hose supplied in half and do both?
I have a similar kit I got from NAPA; some plastic fittings, clips, and hose.
If you're "bench bleeding" a master cylinder I would do both ports at the same time. My kit came with several fittings so I put them on both ports and routed the hose back into the brake fluid to bleed the air. Hope this helps. |
