Old 04-11-2004, 04:18 PM   #1
WB72
Before and After
WB72's Avatar
Exclamation 3/4 ton rear axle
What were the common axle ratios that came in a 72 C20? It is a big unit that the gears come out of the front.
Was there something like 4.11:1? in that rear end? or was that ratio only in 10 and 12 bolt rear ends?
Not Grandpa's C-20 anymore...
383 Stroker 425HP, 485Ft/Lbs
Lowered 3.5" Front / 5" Rear
66,000 miles.
Alberta, CANADA
WB72 is offline   Reply With Quote
Old 04-11-2004, 04:21 PM   #2
Vince M
Vince M's Avatar
4.10 and 4.56 were available from GM. There is a 3.90 available aftermarket.
68 Chevy CST SWB w/LS1, carb & 700r4. Golden Anniversary clone with a few improvements.
Vince M is offline   Reply With Quote
Old 04-11-2004, 10:48 PM   #3
BurnoutNova
BurnoutNova's Avatar
sooo, what your saying is theres no other gers available for a 69 3/4 ton than 3.90, 4.10 and 4.56?
i have a d44/d60 in my 69 and dont know which they are.
i know, its not that hard to fing out but im lazy!
BurnoutNova is offline   Reply With Quote
Old 04-12-2004, 01:36 AM   #4
1969 GMC
1969 GMC's Avatar
the 4.10 and 4.56 were all that was available for the dana 60 rearend in 4x4s, BB 3/4 tons had 3.42 gears.
the eaton ho52, which he is talking about, had 4.11, 4.57, and 5.14 from the factory. however, 3.90 was aftermarket...and was/is the only one made.
dana 60's have a lot of aftermarket gears available. i have the same setup as you...d44/d60...originally 4.10s, but the p/o swapped them out for 3.73, which helps wth gas mileage. i am not sure of all the others, but I know Ford had a 3.54 available in 4x4 d60's.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
