ran out of money
kick down cable for 700R4
Is anyone running a holley double pumper with a 700R4? i have to figure out a way to mount my kick down cable and not have the trans eat itself apart. I was talking to my Trans teacher and he said i have to find out the throw of a stock arm and make something that will pull the cable the same length. I am hopeing someone can help me
Thanks Rat
Modify everything, leave nothing alone!~ ![]() ![]() |
Bowtie overdrives has a kit for all carbs. Thats a TV cable not a kickdown.
1980 Chevy Shortbed Pickup 1969 Z28 engine Turbo 350 |
ran out of money
thats what i ment "TV" sorry....
Yeah I just saw that kit and it is $109, just wondering if someone knew of a way to do it cheaper? Thanks Rat
depending on the model# off your carb holley has a number of cable brackets available for their carbs in the $20 range check out their web sit or a dealer near you
ran out of money
cdowns thanks that is more in my price range
Rat
71Rat,
If you want to try to figure out your own bracket geometry, there are some good sketches and instructions at this link. http://purplesagetradingpost.com/sum...o/700R4p1.html Good Luck!
'56 F-100 (w/all GM stuff) Lookin' for another parts chaser! ![]() '05 GMC crew cab |
I'm going to be buying one for my efi. Here's a link to the Holley brackets on Jegs site
http://www.jegs.com/cgi-bin/ncommerc...30&prmenbr=361
Tom 1968 C10 LWB. 402 BB, Holley MPI, 700R4. 4wheel Hydroboost Disk Brakes. |
Progress = 0%
The Bowtie Overdrives kit is well worth the money. Not only does it provide the correct "throw" for the cable, but it also allows you to adjust the "feel" of the shifting from aggressive to mild. It's money well spent IMO.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
ran out of money
anyone use some of those holley type brackets? i am looking at their throttle cable hold down and tv cable bracket......... The bowtie overdrive looks nice, but i am looking at all my options first thought... thanks slammed67 for the words of advise
![]() Join Date: Jul 2000
I used GM parts. TV cable p/n 2515598 and cable bracket p/n 22504927. Less than 20.00 each. bracket mounts to back two carb bolts and has hole for throttle cable also.
68 Short Stepside, 350, quadrajet, 700r4, 3:73 posi, power front discs, HEI, Factory Air, Tilt, Tach, accelerator cable instead of rod, sway bar. 96 Impala SS 97 Monte Carlo |
ran out of money
Don Smith- thanks for the input about the gm parts
