Old 04-14-2004, 12:21 PM   #1
angelsairman
Future Owner
angelsairman's Avatar
Question Intake Manifold Gasket Question
I need to purchase a new set of intake manifold gaskets. Im going to get felpros but i dont know which one i would need as there are several types listed
http://www.northernautoparts.com/Pro...?ProductId=296
Im pretty sure i just need the stock ones but im not sure on the blocked or unblocked heat crossover as i have no idea what they are talking about. Orignally i purchased just a stock set of felpros when i built the engine...so any help would be apprecited...and just in case it helps my heads are stock castings with i believe 2.02/194 valves 3 angle valve job and the intake is a Edelbrock Performer EPS...
Its not the end result that counts most...its the journey along the way that's most rewarding
My truck doesn't leak, it just marks it's territory
angelsairman is offline   Reply With Quote
Old 04-14-2004, 12:44 PM   #2
Sweet72
Sweet72's Avatar
You should use the one with the blocked heat crossover on the Edelbrock Performer man. Stock truck manifolds had the exhaust crossover in the center of the man. to warm the air and allow the choke to open when the manifold heats up.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 04-14-2004, 12:52 PM   #3
Sweet72
Sweet72's Avatar
Edelbrock recommends this set of gaskets for your intake
PN: 7201
