Old 10-31-2004, 05:06 PM   #1
gutterman01
Brakes
Has anyone used a 1988 master cylinder and booster on a 67-72 chevy truck also the steering box will it bolt up?
gutterman01 is offline   Reply With Quote
Old 10-31-2004, 06:40 PM   #2
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
i am pretty sure it is only 69-87 p/s boxes that work. for a 2wd if thats what you are talking about. just look at the difference. does it still bolt on the outside of the frame. 4 bolt holes. the rag joint the same? as far as the master and booster, i cant help there
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 10-31-2004, 09:42 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
88 and newer steering boxes bolt inside the frame, rather than outside like 87 and older trucks do.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 10-31-2004, 10:37 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
The 67/early 68 frame needs light mods to use a later box. There is a dimple that needs placed on the frame rail.
The gear box from 73 - about 80 will work fine. The later ones will work, but the hose connections are o-ring style, and metric.
The master cylinder, i wouldn't touch it myself if you have a 67 - 70...(drum/drum verses disc/drum) And honestly, onless I had swapped the whole 73 - 87 brake system to the older truck, I still wouldn't do it.
Old 11-01-2004, 12:25 AM   #5
Longhorn Man
Here's a pic...
The little plastic deal on the booster, at the end of the (steel braided) hose.
Old 11-01-2004, 12:26 AM   #6
68w/sbc406
68w/sbc406's Avatar
hey andy wrong brake thread
