Old 06-25-2002, 11:25 PM   #1
68gmcjon
Got earplugs?
68gmcjon's Avatar
?????Headers??????
I've been thinking about getting headers now for a while. What difference would it make it the exhuast sound with performance mufflers?
68gmcjon is offline   Reply With Quote
Old 06-26-2002, 04:57 AM   #2
Super Chevy
Super Chevy's Avatar
youll pick up a good 20hp from switching from a single pip in some applications,headers and a nice set of mufflers sound killer,you can hear each cylender fire,were as with the stock manifolds it was kinda muffled,I'd go with a set of crematic coated ones ,they'll last close to forever and they shine
SC
Super Chevy is offline   Reply With Quote
Old 06-26-2002, 09:21 AM   #3
VNMOUS
Step Side's Rule
CAN'T BEAT THE SOUND FROM A GOOD SET OF HEADERS ! ! !
DANO
07 Silverado Classic
67shortstep
76 stingray
95 cobra
66 Mustang Coupe 289
VNMOUS is offline   Reply With Quote
Old 06-26-2002, 10:49 AM   #4
Low69CST
I've got a set of ceramic coated full length headmans running through 3" dual exhaust and 40 series flowmasters. I can't wait to get my heads so I can hear this rumble. Theres also some negatives with headers. Keeping gaskets in them is a big problem. Theres more heat that comes off headers also. You can have a problem with burning up your plug wires also. These aren't terrible problems, but should be kept in mine when thinking abo ut headers.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 06-26-2002, 04:03 PM   #5
lukecp
Formerly yellow72custom
lukecp's Avatar
When i made the switch from ramshorns to headers, it made my
truck sound about twice as good, and alot louder . That was
back when i had 2" duals and short glasspacks though. When
i added a set of flowmasters, it made it sound even better. You
may want to get some header bolts with the allen wrench heads on
them, they are alot easier to torque down then the regular kind with
3/8" hex heads on them. I have a combination on hex and allen bolts
on mine, i put them where each one was easier to get at. I wouldn't
use the cheap gaskets that come with the headers, you will proably
have to replace them pretty soon. I use Fel-Pro gaskets on my headers,
and i haven't had to touch them in over a year. The "dead soft" gaskets
are sopposed to be good, but they are fairly pricey. Good luck
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 06-26-2002, 04:09 PM   #6
diggin69
Southern but in Ohio!!!!
diggin69's Avatar
Headers are a MUST on any truck.....like everybody says... headers+torq+power=
1969 C/10 3/4 ton 4x4 longbed custom, frame made from a 79
1972 custom-10 half/ton longbed
1980 1/2 ton 4x4 all original 350/350/205 with air
Eaton,Oh
rebelryder@hotmail.com
diggin69 is offline   Reply With Quote
