Old 11-02-2004, 07:30 PM   #1
Rod
Toolpimp here's the info
Heres a pic of the hubs we talked about.. I never told you about the warn hubs that will also fit. They are 19 spline and thats the correct axle in the pic also. Also shown is the Ford hub I told you that would fit also.
I opened up a spicer hub to show you the parts all in there.
I know the stuffs hard find.... and I know you need it. Let me know if you can't get anything.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 11-02-2004, 07:33 PM   #2
Rod
1970 and 1971 vin decoding.
Here's how you decode a GMC vin from 70 and 71....so its a 70 GMC vin you showed me , not a 71 as someone else told you.
Your front drums are a 1 year only item...harder to find than the hubs in my opinion.
Old 11-03-2004, 12:59 AM   #3
Rod
Remembered about the older spicer hubs also.. they will work also.
typical 67-69 stuff. It should bolt on to a 70-72 also.
Old 11-04-2004, 12:50 AM   #4
Rod
Here is a pic of Warn hubs on a 69 3/4 ton.
I can't remember if it needs the about 3 inch thick spacer like the spicers or not... I'll go look at it tomorrow.
