Old 11-03-2004, 12:42 PM   #1
70-Chevy
-Chris
70-Chevy's Avatar
Engine wont start
The other day when i started my truck in the morning to go to work, i let it warm up and it ran fine. I started onto base and the damn thing was idling at 4000 rpm at stop and at 55 mph with the stall converter i have. i had to stay on the brakes. I parked it to go run with the platoon and when i came back to it to go home, i started it and it ran high idle again. As soon as i got off base, the damn thing wouldnt stay running if i didnt keep my foot on the pedal. It finally broke down in my neighbor hood. It was backfiring through the carb and exhaust before it finally shut off. It had no power what so ever.
I got it home, I replaces wires, plugs, cap, rotor, coil, and module. still no start ?
1970 Chevy C-10 P/U, Shortbed, Fleetside - 5/7 drop, 496, TH400, 12 bolt.
BUILD THREAD - http://67-72chevytrucks.com/vboard/s...d.php?t=404481
2012 F250 Super Duty P/U - intake, exhaust, tuner, 4" lift with 35's
2017 Chevy Suburban (Wifes Car)
- Fully Loaded & Stock
"Some people spend an entire lifetime wondering if they made a difference in the world. But, the Marines don't have that problem."
Ronald Reagan, President of the United States; 1985
70-Chevy is offline   Reply With Quote
Old 11-03-2004, 02:01 PM   #2
norville
What carb? I had an edelbrock that would stick. I would have to remove the top of the carb and clean the junk out of the bowls. I got pretty quick at it. To me it sounds like maybe your needles are sticking.
norv
1986 C10 Scottsdale
5.3, TH400
norville is offline   Reply With Quote
Old 11-03-2004, 02:22 PM   #3
HuggerCST
HuggerCST's Avatar
First things that come to mind- Big vacuum leak, or maybe the distributor worked loose, and the timing is off. Pull a plug & check for spark, and make sure it's getting fuel.
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 11-03-2004, 05:42 PM   #4
junkyardjohn
junkyardjohn's Avatar
SOUNDS LIKE A BIG VACUUME LEAK TO ME ALSO. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 11-03-2004, 07:07 PM   #5
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
I thought Vacuum leak also.Is there anything obvious like a hose gone,or cap gone.Gas on the intake,anything unusal like that?
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
