Old 11-06-2004, 06:13 PM   #1
guyryan100
guyryan100's Avatar
prevent engine rotation
I'm trying to torque the damper into place... I've only got 1/16" left to go but the crank is spinning now (at about 55 lb/ft). I put in the spark plugs which helped a bit but I e\need to keep the crank from turning - what's the technique??
guyryan100 is offline   Reply With Quote
Old 11-06-2004, 06:19 PM   #2
cduster
I have used a screwdriver wedged inbetween the teeth of the flexplate and the block.
Never had any problems that way, although it might not be an acceptable practice.
Dan
cduster is offline   Reply With Quote
Old 11-06-2004, 06:33 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Shove a looong flat head inbetween the torque converter and fle plate. Let it turn untill it smacks the bellhousing...it won't move any more.
Just remember to remove it before starting engine.
Old 11-06-2004, 06:59 PM   #4
junkyardjohn
junkyardjohn's Avatar
MAC & SNAP-ON BOTH MAKE TOOLS TO TURN FLYWHEELS & FLEXPLATES. THEY WONT DAMAGE THE TEETH OR BEND THE FLEXPLATES. THE TOP ONE IS A MAC & THE BOTTOM ONE IS A SNAP-ON . JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 11-06-2004, 09:56 PM   #5
guyryan100
guyryan100's Avatar
In the end I just put a C-clamp on the flexplate and that did the trick.
Old 11-06-2004, 10:35 PM   #6
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
Large vise grips will do the job nicely as well.Clamp them on the flexplate,and torque away.
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 11-07-2004, 05:55 AM   #7
grayw0lf
Who needs a torque wrench??? They are just play toys for girls! Get your impact wrench & tighten until you can't tighten any further. The bolt heads will pop right off when they are properly torqued.
85' CUCV M1009!!! The newest addition!
6.2diesel, Th400, NP208, & only 36k miles!
70' C-10 LWB Fleetside - Looking good these days!
05' Dodge Neon
88' Winner Escape Sport 1750 - 4.3v6
94' Seadoo SP
84' Honda TRX200, bare nekkid. Just a frame & tires.
Always looking for another project or any good deal!
grayw0lf is offline   Reply With Quote
