Old 11-07-2004, 08:22 AM   #1
OhioDan
OhioDan's Avatar
Question Routing Plug Wires?
I have a 350 with rams horn exhuast manifolds. Is there a way to route the plug wires from the bottom side of the manifolds back to the distributor? If I go over the top, chances of burning plug wires are high. Did they come from the bottom originally? Had headers before, and this wasn't a problem. Want to go under the manifolds to cleanup engine appearence. Any help would be appreciated. Thanx.
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline   Reply With Quote
Old 11-07-2004, 08:26 AM   #2
GMCPaul
The wires were originally routed underneath, first they run to a 4 wire loom on rear of bellhousing, then route underneath using a combination of single wire retainer at oil pan and dual wire retainers on block. If using HEI get tailored plug wires for a 1974 Corvette, the 74 vette used HEI and routed the wires the same way.
GMCPaul
GMCPaul is offline   Reply With Quote
Old 11-07-2004, 08:48 AM   #3
OhioDan
OhioDan's Avatar
Thumbs up
Where can I get the retainers? Do they sell them aftermarket? Plug wires are Accel trim to fit, so no problem there. Thanx.
Old 11-07-2004, 08:58 AM   #4
GMCPaul
Thumbs up
We carry the retainers as do most vendors, we are currently out of stock on the 4 wire bellhousing retainer, & the 1 wire oil pan retainer altough I do expect to have these back in stock some time next week because I placed a order for more the beginning of last week. Got a ton of double wire retainers in stock.
GMCPaul
