Old 11-08-2004, 09:32 PM   #1
Rod
Updating 1 ton dually front discs question?
Anyone updated there front discs on a duallie 71 or 72 1 ton to newer years rotors, calipers etc...what problems or things should one know? How about the older 67-70 one tons duallie to newer discs?
Do you need upper control arms or such? Rod
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 11-10-2004, 10:41 PM   #2
Rod
Ttt
Old 11-10-2004, 10:46 PM   #3
longhorn71
longhorn71's Avatar
i think you need all the same parts just like the 1/2s.i think the 71-72 rotors are the same as the newer trucks 73-87
longhorn71 is offline   Reply With Quote
Old 11-11-2004, 12:55 AM   #4
junkyardjohn
junkyardjohn's Avatar
ROD..... I'VE GOT A WHOLE FRONT CROSSMEMBER ASSY. OUT OF A 1985 THAT I PLAN ON PUTTING UNDER MY 69 1 TON TOWTRUCK, WHEN I REPLACE THE 350 WITH A 396. HOPEFULLY THIS WINTER. THE 85 WAS A BIG BLOCK TRUCK, SO I GOT THE M/M TOWERS, STEERING GEAR BOX ALL AS AN ASSY. SHOULD MAKE FOR A GOOD UPGRADE. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 11-11-2004, 08:29 AM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Ttt
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 11-15-2004, 04:18 AM   #6
Duallie
Duallie's Avatar
I replaced the stock 12.5x1.25 rotors on my 72 Cab-n-Chassis with '77 12.5x1.5 rotors from a "CamperSpecial 10,000lb" crewcab. I reused the A-arms, replaced the balljoints, and bolted on the new spindles. No tierod alterations. The spindles are completely different, but still bolt on. I did end up running new stainless brake lines and braided hoses. The calipers are huge!
I used the hydroboost, too. During a major panic stop last year I was able to lock the front tires, and that's with a Camaro on the bed!
Does this answer your question?
Just as if I knew what I was doin'
Duallie is offline   Reply With Quote
Old 11-15-2004, 10:05 PM   #7
Rod
Ok so its the calipers, discs and spindle I need to grab... would you know if they used the same bearings.....hmmm....well I guess not if the spindles needed to be changed.
I might be able to grab a 77 Grumman van set up myself.
