Old 11-10-2004, 01:47 AM   #1
Hooter
My other Love
Hooter's Avatar
brake light and signal light problem
well the truck is hibernating for the winter now , but before I parked it, the brake lights worked fine, the signal lights worked fine, but when Id hit the brakes while the signal light was on, the signal light would quit, it does this when both the right and left signal light are used, so what gives?
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 11-10-2004, 06:29 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Sounding like a turn signal switch.
Old 11-10-2004, 08:15 AM   #3
70c10
67-72 Addict!
70c10's Avatar
Andy is probably right. Look on ebay, there is a guy that sells new AC Delco turn signal switches for our trucks for like $14.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 11-10-2004, 08:30 AM   #4
neonlarry
neonlarry's Avatar
Before you buy a new switch I would go thru and clean all the ground connections for your lights. It might help and it might not but at least its cheap.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 11-10-2004, 03:51 PM   #5
Longhorn Man
I doubt cleaning the grounds would do anything...the ground is good enough for the amperage of the brake lights, which is the exact same as the turn signal since it is the same filliment.
Old 11-11-2004, 02:52 AM   #6
69ChevyLB
Active Member
69ChevyLB's Avatar
I think it's working as it should. I think Andy's right that it's the same filliment and if it is it can't blink and stay on continous at the same time.
69 C10 LWB Project
47 Cushman Scooter Project
It is better to have loved and lost than to live with a psycho all your life.
69ChevyLB is offline   Reply With Quote
Old 11-11-2004, 03:02 AM   #7
sdkid
Does the taillight quit, or does the dash indicator quit?
sdkid is offline   Reply With Quote
Old 11-11-2004, 09:40 AM   #8
purple gas
Always check the easiest things first, I say, cause I'm lazy. See if your front signals work, see if your bulbs are ok, see if your blinker is burnt out, and poke around with a test light before you pull your signal switch. As for blinking. The brake light / signal use the same filamint. The signal is just a blinking brake light
purple gas is offline   Reply With Quote
Old 11-11-2004, 04:11 PM   #9
Hooter
My other Love
Hooter's Avatar
all the bulbs are working just fine and all are really bright, its just when I have the signal lights on and I hit the brake the circuit that is flashing stop flashing and just dims
pictures of my life
Old 11-11-2004, 11:49 PM   #10
Hooter
My other Love
Hooter's Avatar
found the problem today, I had one of those Hoppy inline tralier wire connectors in the back, and as soon as I unhooked it and plugged the taillights back in, everything started working fine, so there is obviously something wrong inside of the trailer connector
pictures of my life
