Old 06-27-2002, 11:22 AM   #1
my new 72
faster, faster, faster
my new 72's Avatar
Holley electric fuel pump.
I thought it would be better to word the topic differently. Who has one, and where did you mount it? I am about to install one, and need some ideas. I was thinking the frame rail under the cab, but I am not too sure. The way it looks the pump will have to be mounted on the drivers side, because the position of the inlet and outlet ports, or I could put it on the outside of the frame rail. What do you guys think? Any help is appreciated.
I'm going to Law School, wanna debate? It's good practice.
my new 72 is offline   Reply With Quote
Old 06-27-2002, 11:32 AM   #2
Low68
Low68's Avatar
If it was me I wouldn't want to mount it on the driver's side.
I would try mounting it on the passenger side. It might be alright on the outside depending on where and wheter there would be a lot of crud coming up from the tires. Good Luck
Build Thread
Low68 is offline   Reply With Quote
Old 06-27-2002, 11:35 AM   #3
Blue68
Blue68's Avatar
I have a Carter that I mounted on the inside of the frame rail just in front of the rear axle on the passenger side. Reason is that I'm going to a rear tank eventually. For now I just run lines back to it and back forward.
I would be very hesitant about putting it on the outside of the frame rail. Too much exposure to road debris that could damage it or knock the lines loose. But also take into account your exhaust system location as well.
As for which side you place, the choice is really up to you. I like the passenger side because that is the side the fuel inlet is on for the carb and the way my tank is set up. Plus I can use the existing line brackets that are above the brake lines to hold them in place.
http://home.comcast.net/~r.landrum/w...tos.html-.html
'68 C-10 LWB, '98 Z-71 350 w/accessories (Serpentine), Edelbrock Performer, Edelbrock 1405 (600cfm) carb, GM HEI, CompCam Extreme 4x4 roller cam, Thorley Headers, Carter Electric Fuel Pump, Vintage Air, 700r4, 3.73, disc brakes and power steering upgrades.
Blue68 is offline   Reply With Quote
Old 06-27-2002, 11:53 AM   #4
my new 72
my new 72's Avatar
The only problem with mounting it on the inside of the frame rail on the passenger side is that the in and out ports are facing the wrong way if I do. The in faces the front of the truck, and the out faces the rear. Do you see the dilema now?
Old 06-27-2002, 12:00 PM   #5
Blue68
Blue68's Avatar
Not to be snotty, but turn it around.
The bracket that came with my Carter allows it to be rotated in any position. From the looks of the Holley pictures, you should be able to do the same. Loosen the bolt that clamps the bracket to the pump body and spin it. It looks like the clamps that come on the old style coils.
What am I missing?
Old 06-27-2002, 12:04 PM   #6
my new 72
my new 72's Avatar
Thats okay, the base sticks out further on the opposite side, so I cannot turn it around. I already thought of that. Thanks though, you are right sometimes the obviouse answer is the best one, but not in this case.
Old 06-27-2002, 12:15 PM   #7
Blue68
Blue68's Avatar
Figures. The pics don't show the base on the otherside. Ever considered a Carter? It's probably a little bigger but the mounting bracket is a sizable L bracket that the pump hangs down from. The pump has three threaded mounts. The top of the bracket has several holes in it that allows you to spin the pump to a couple different positions.
I'm guessing it can't be mounted upside down either.
Old 06-27-2002, 12:30 PM   #8
71BBK10
Teufelhunden
71BBK10's Avatar
which pump is it? i have the holley red electric pump and i was able to loosen the little screw on the back and turn it around and mine is mounted in the passenger side frame rail, i guess if you can't do that you could spend the money on some fittings to it so you don't have to put it on the drivers side. just a thought. i'll take a pic of mine if ya want
1971 K10 lwb fleetside 402 T350 205
71BBK10 is offline   Reply With Quote
Old 06-27-2002, 12:52 PM   #9
RipMeyer
RipMeyer's Avatar
I thought the topic was holy erratic fuel pump (Batman). LOL
RipMeyer is offline   Reply With Quote
Old 06-27-2002, 01:44 PM   #10
Slammed67
Progress = 0%
Slammed67's Avatar
Also keep in mind that those pumps "push" the fuel, and not "pull" it from the tank. The fuel needs to be able to gravity feed into the pump, then it will push it from there. If your tank is in the stock location, I'd mount it to the outside of the frame rail on the passenger side. I've got a fuel cell under the bed and have my pump mounted to the outside of the frame rail, behind the axle.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 06-27-2002, 02:48 PM   #11
71BBK10
Teufelhunden
71BBK10's Avatar
here, i'm gonna try and post this pic, i'm a pic posting virgin so bear with me
Old 06-27-2002, 02:58 PM   #12
Blue68
Blue68's Avatar
Pretty good for a virgin. Felt good didn't it.
Old 06-27-2002, 03:03 PM   #13
71BBK10
Teufelhunden
71BBK10's Avatar
hehe, i had to downsize it twice, that part you guys didn't see, this digicam **** is addictive, i'm takings pics of everything.....
Old 06-27-2002, 03:10 PM   #14
71BBK10
Teufelhunden
71BBK10's Avatar
another one...
Old 06-27-2002, 03:25 PM   #15
my new 72
my new 72's Avatar
What I was thinking about was making a little spacer just big enough to compensate for the lip on the other side, and turn it. it's mor than I wanted to do, but I guess I'll Have to do it. I would rather have it on the inside of the framerail for appearances.
Old 06-27-2002, 04:05 PM   #16
nosto
Flamin' Bass
nosto's Avatar
Mine was installed inside the pass. side frame by PO. Was noticably noisy (BZZZZZZ) all the time it was on, but I guess that's nothin' a few $$$ of Dynamat won't cure.
I went to the rear poly tank and located the pump on the cross piece just behind the rear, in front of the tank. Don't worry: I've changed the fuel linie location so it won't get hit by the panhard.
Slammed67: Any problem with this installation sucking gas out of the tank, or is that only a problem for longer runs??
Rick Olson /nosto/
Galloway, NJ
Pics : http://community.webshots.com/user/nosto53
1972 Triumph TR6 - full resto, now with a Toyota 5-speed
1975 F**D F-100 - rusty, but reliable
1982 HD XLH-1000
1967 C-10, shortstep, 350/M21 4spd, nitrogen tank fills fast bags on 4 corners, Toyo 255/45X20s on American Eagle 221 20X8s, shaved locks and handles, antenna, fuel filler, tiny C-notch, rear fuel tank, long headers, Edelbrock, worn 600 Holley, Checkmate flush hard cover, rear pan, custom LED taillights - painted it, too! But don't like it so I'm gonna do it again!!
nosto is offline   Reply With Quote
Old 06-27-2002, 06:18 PM   #17
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
For the high level of annoying buzzing these things do, you can use longer bolts, and put an old shock bushing in there. That'll shut it up, and it will also reduce the vibrations it gets from all those city pot holes you have to hit. That should make it last a little longer.
Old 06-28-2002, 09:21 AM   #18
my new 72
my new 72's Avatar
Thats a good idea. I was thinking about just a rigid mounted spacer, but a good thick rubber one is even better. Thanks
Old 06-28-2002, 01:56 PM   #19
chevy2racr
So Many Ideas, So Little Money
chevy2racr's Avatar
we now have one on our 85 Camaro and here are a few tips. I'd say bigger pump with a regulater(blue holley pump comes wiht one. if you have clearence problems, get some washers. on the camaro we ran #8 braided steel line. plenty of volume that way. and since as mentioned, these are not suckers, they are pushers, we got some manley AB apoxy(like used to build up heads) in bar form. and a "bung" for a fitting to screw to, drilled a hole in the bottem of the tank and apoxyed the bung to teh tank to gravity feed the pump better, works great, just make sure you let the apoxy set for a good 8 hours
Bryce
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors
71 C10 with 454
99 S-10 5.1L SBC 700R4
09 Malibu
Marshalltown, Iowa
chevy2racr is offline   Reply With Quote
Old 06-28-2002, 05:54 PM   #20
Longhorn Man
heh heh...he said BUNG!!!
Old 06-29-2002, 10:05 AM   #21
Lippyp
English Chevy Owner
Lippyp's Avatar
I have a Carter mounted on the outside frame rail just forward of the in-cab tank. Works fine, but I agree about the noise. Will try a rubber mounting.
I was also thinking about boxing it in, this would give the pump some protection from all the crap and salt in the winter chucked up from the wheels and also allow me to add some sound insulation, anyone done this?
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
Old 06-29-2002, 11:17 AM   #22
my new 72
my new 72's Avatar
The only problem with boxing one is that it may get too hot and burn up.
Old 06-29-2002, 06:46 PM   #23
Longhorn Man
Who cares if the outside of it gets dirty. Put some RTV over the connections, and forget about it.
