Old 11-11-2004, 04:05 PM   #1
indianmotocycle2001
tranny for 327
Here's a question.....I am putting a 327 into the old 49 chevy. Which tranny would be good to use?? I have found a 350 turbo with overdrive which is in a truck attached to a 305 motor. I was told by a friend that the auto tranny that came in the 88 chev s-10 with a 2.8 liter v-6 which I have would work ?? Dont know about that one though. Any help would be nice thanks
indianmotocycle2001 is offline   Reply With Quote
Old 11-11-2004, 04:40 PM   #2
DennyB
Led Sled! Discs R 4 ME!
DennyB's Avatar
If you have a overdrive trans then its not a TH350.
What would bolt up to the 327 is a 700R4 from A SBC or a 4.3L.
A 2.8L has a different bolt battern Its a 60 degree V6 where as 4.3L is a 90 degree V6 Which is the same as the V8.
If its an overdrive trans connected to the 2.8L odds are its a 200R4.
This is still a good trans although bolting it to a 350 would requite other adaptors that may make it cost prohibitive.
Hope this helps.
"Never ride faster than your Angel can fly"
I.M.O.M,W,J&C
Patriot Guard Rider
DennyB is offline   Reply With Quote
Old 11-12-2004, 10:45 PM   #3
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
The 700r4 would be a good swap.The overdrive will greatly improve MPG.
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 11-13-2004, 09:46 AM   #4
DennyB
DennyB's Avatar
Plus it will give you a lower first gear.
I.M.O.M,W,J&C
Patriot Guard Rider
Old 11-16-2004, 09:03 PM   #5
Apache
Apache's Avatar
One of my grandpa's has a s-10 with a 2.8. And Denny is right, the bolt pattern is different. Your friend was probally thinking about the auto's that come with the 4.3, instead of the 2.8.
54 Chevy Bel Air 4dr powerglide
54 Chevy SWB
58 Chevy Big Window SWB Fleetside project
58 Chevy LWB 235/4spd
76 Chevy Nova 350/TH350 4.88's *10kmiles on "new" engine
79 Chevy 4x4 SWB 350/4spd 3/4 ton
81 Mazda RX7
84 F@!d Mustang
96 F@!d Ranger 2.3L/5spd
Apache is offline   Reply With Quote
Old 11-24-2004, 12:19 AM   #6
indianmotocycle2001
thanks...I'll go with the 700r4...not a bad deal trading the 200,000 mile plus 2.8 and it's trans for the 700r4 with 80,000 miles on it
Old 11-24-2004, 12:38 AM   #7
Brainchild
Brainchild's Avatar
No I'd do it
Rusty Member #13872
71 GMC LWB
49 Chevy
85 Chevy G20
Old 11-24-2004, 08:41 AM   #8
Seon
Seon's Avatar
With a 700r4, have at least 3:73 gears. Anything higher may rob you of mpg.
Seon is offline   Reply With Quote
