11-13-2004, 10:34 PM | #1 |
Watch out for your cornhole !
For sale- lowered, big block, shortbed truck
It's time to sell the famous Tx Firefighter Cool As Hell (TM) truck.
I'll supply proof of over 7 thousand dollars spent in parts alone in the last 18 months. I'm asking 6 thousand dollars for the truck. I'm the third owner of this thing. It's an original Texas truck with worn out original paint on everything but the front fenders. It's a solid truck, it doesn't need rockers or cab corners or any of that stuff. I bought this truck as an untouched original 6 cylinder 3 speed no option truck. Everything listed below, I've done, and all has less than 5k miles since I did it. It's got a 35k mile since new 454 engine, a fully bulletproof turbo 400, new 1 piece driveshaft. Converted to 5 lug front and 3.08 rear. Lowered 4.5 and 6 using all the good stuff from ECE, super track bar, short KYB shocks..... All new brakes, booster, master cylinder, hoses, bearings, calipers, pads, shoes, wheel cylinders.... Engine has been resealed with all new gaskets, seals, timing chain, new water pump, fuel pump, belts, hoses, 4 core radiator.....Edelbrock intake, Edelbrock 750 carb, new HEI..... It's all detailed with POR 15 paint, lots of bead blasting, all correct and original pulleys, brackets, mounts, fan shroud...it's all done right. You can buy any part for an original big block truck at the parts store and it will fit like it should. Inside has a tilt column, new dash pad, original uncut dash, radio block off plate, late model truck steering wheel. Has 15x8 Cragars all around with BFG tires. Converted to power steering, power brakes, and big swaybar. The swaybar is the FAQ article that I did, you can see picture of it over there. I converted the front clip to 72 style with a billet grille insert and new chrome bumper. This truck drives straight, doesn't leak, rub, bump, or grind. My wife can drive this truck without any trouble. I was a mechanic professionally for 12 years, so I do stuff right. I'm also an obsessive freak, so stuff has to be neat too.
I'm on the Instagram- @Gearhead_Kevin Last edited by Tx Firefighter; 11-13-2004 at 10:40 PM. |
11-13-2004, 10:49 PM | #2 |
11-13-2004, 10:58 PM | #3 |
New GM cab mounts too. New NOS GM exhaust manifolds, dual exhaust with Dynomax Super Turbo mufflers, new battery cables, Lokar kickdown kit for transmission.
Since these pictures, I did the new dash pad, tilt column, new steering wheel, and converted dash to guages from idiot lights, and put original block off plate in dash.
11-13-2004, 11:15 PM | #4 |
PM on the way.....
jerrykay@austin.rr.com |
11-14-2004, 08:10 AM | #5 |
All PM's answered
11-14-2004, 08:12 AM | #6 |
Real nice truck, good luck on your sale!
1968 Chevy 4x4 307 4 speed |
11-14-2004, 01:00 PM | #7 |
I'd swap it for a nice 67-72 dually or even an early 73-87 style of dually.....
11-14-2004, 08:22 PM | #8 |
Someone step up or I'm going to part it out next week.....seriously.
11-14-2004, 08:36 PM | #9 |
part out a 6000 dollar truck ?
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon) WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt. |
11-14-2004, 08:39 PM | #10 |
Still Green but learning
Always so far away!!!
-- Cory 71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab 07 Suburban LTZ 4x4 2010 Acura TL 98 Mastercraft "FrankenStar" 225 27253 UPS/USPS IIOY....nope never was |
11-14-2004, 08:54 PM | #11 |
your probably not interested but i got a 95 dodge 1 ton 4x4 w/ the ctd in it ill trade you.
every man must believe in something, i believe ill have another beer! |
11-14-2004, 08:59 PM | #12 |
nice truck , please dont part that out. it would make someone a good truck.good luck.
11-14-2004, 09:11 PM | #13 |
BlahBlahBlah
wow i hate to see you part that but if it comes down to it...i would be interested in your complete drop kit if it would work on my 72 burb.
11-14-2004, 09:38 PM | #14 |
Active Member
Don't part it out , Let me see if I can get my truck sold and see what we can come up with.
11-14-2004, 09:54 PM | #15 |
its all about the +6 inches
I have the perfect truck for you to part out....if you really want to part something out, let me know and I'll trade you trucks.
TTT for ya tex. |
11-14-2004, 10:23 PM | #16 |
FARMER/RANCHER
I think I can get you a 67 or 68 short wheelbase dually. With a 327 in it. it was running propane but hasn't ran in a while. I think the head cracked. it has no bed on it. and is a one ton.. let me know.
1972 chevy super, long box, 402 big block (2,000 miles on rebuild) 2wd tach, tilt, tool box on bedside, a/c, sliding rear window, orange and white. 1972 Chevy Blazer 2wd, tach, tilt, a/c, my first engine overhauling experience, Orange, with white top 2006 Gmc Sierra, XM, Z-71, dark blue, onstar, leather, rear entertainment (audio only) heated seats, (the wife loves that feature) upgraded tires immediately after purchase to Goodyear Wrangler AT/S (hate those rock throwers that come from the factory) BWC |
11-14-2004, 10:30 PM | #17 |
a SWB one ton dually???
11-14-2004, 10:38 PM | #18 |
I think he means a 133 inch dually rather than a 157 inch truck.
11-14-2004, 10:40 PM | #19 |
duh...I shoulda known that.
Where is the smiley face with crossed eyes saying DUH? |
11-15-2004, 12:29 AM | #20 |
FARMER/RANCHER
lol, Is that something that you are interested in? I would have to get ppics this next weekend. Let me know..
11-15-2004, 02:51 AM | #21 |
C/10 CLUB MEMBER
Hate to see all your work parted out, but if you really do I would be interested in your nice grille conversion and cragars.
-Ron- |
11-15-2004, 02:53 AM | #22 |
if u end up parting it can i get the auto linkage?
11-15-2004, 02:59 AM | #23 |
Not Mine But A beauty
i would not part that out no matter wut
68 Chevy Shortbed 454/400 2000 Chevrolet Camaro SS 6spd 2011 Silverado 5.3 6spd auto |
11-15-2004, 08:00 AM | #24 |
Chevy72402, I already have a 72 dually, I just need one on the road right now. My dually needs work to be ready and I have business waiting on me. I need a runner right now so I can work ASAP. I don't think I'd want another non runner right now.
Everyone else, it's just a truck. There's thousands of them all over the place. It wounldn't be sacrilege to part it out. That 454 is worth some coin and so is the lowered chassis stuff. I think I can make it worth as much as parts as it is assembled. All of the stuff underneath the truck has been detailed and rebuilt, so I won't have any trouble selling it off on the parts board.
11-15-2004, 05:59 PM | #25 |
Fellows, there seems to be some confusion here amongst some guys. I do not have time to wait around for this thing to sell.
I'm dead serious when I said I'll part the truck out. If it's not sold and gone by the weekend, I'm pulling it apart on Saturday. No joke. I'm still waiting on some emailed pictures on possible trade deals for running duallys, otherwise, it's going to be a busy Saturday. See, I have a welding/ fabrication business and I need another work truck, like bad. My 72 dually has no drivetrain in it now, so if this truck doesn't sell by Saturday, the 454 and transmission and all of the stuff that goes with it is getting stripped out of the short bed and put into the dually so I can use it to work starting Monday.
