Old 11-14-2004, 09:39 AM   #1
JPSAUTO
Question A Little Help With Steering Pleeeeaaassseee
Here's the problem, 69 2wd with p.s., I'm using later 1/2 ton (73 -87) spindles on the 69 control arms. All parts are new and power coated for the steering. I have 69 draglink, steering box, idler arm, inner tie rod ends and sleeves. I was going to use the later outer tie rod ends to fit the spindles but in assembling the steering I found one thing I forgot to check, the diameter of the sleeves the 69 measures .615 the 73+ measures .685. I guess the first solution is to replace everything with the later components a large expense, is there any cheap way out, could the outers be cut down and re-threaded or are there sleeves made to accept both sizes???? Any suggestions ????
JPSAUTO is offline   Reply With Quote
Old 11-14-2004, 10:04 AM   #2
Sweet72
Sweet72's Avatar
Take the spindles to a machine shop and have the outer tie rod holes machined larger to fit the '69 outer tie rod end.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 11-14-2004, 10:24 AM   #3
JPSAUTO
The problem is not with the bore in the spindle but the threaded shaft diameter.
Old 11-14-2004, 10:38 AM   #4
Sweet72
Sweet72's Avatar
Yea I know, 73-87 spindles with a '69 drag link, '69 sleeve... With my suggestion he could use all four '69 tie rod ends. If he has the tie rod end cut down and re-threaded to fit the sleeve he's gonna have to do that again when the tie rod end wears out. The spindles are a more permanent fix IMO.
Old 11-14-2004, 11:36 AM   #5
Harold Shepard
Golden State when Seth Daulton owned it, had Brian McCormick do a write up on the same swap (same model truck, same basic components). According to the article the swap was relatively painless. They moved the old outer tie rod (69-70) to the inside position and replaced the outer tierods with 73- up inner tie rods, they used 73- up dropped spindles and replaced the upper and lower balljoints in the 69-70 with 73- up models. They did not mention anything about problems or drilling etc. other than modifying the location of brake line/ hose attachment. I am planning on the same swap for my project truck, keep me informed.
Harold Shepard is offline   Reply With Quote
Old 11-14-2004, 12:59 PM   #6
JPSAUTO
Harold, the threaded ends that go into the adjusting sleeves are different diameters. That's the rub.
Old 11-14-2004, 01:07 PM   #7
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Several vendors sell an adapter tie rod sleeve, one thread on one end, different thread on the other end.
I'll see if I can find one on the web somewhere. Sit tight..
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 11-14-2004, 01:09 PM   #8
JPSAUTO
Thanks TX
Old 11-14-2004, 01:17 PM   #9
Tx Firefighter
Here is a thread where they discussed the whole deal. Some years are different, but the problem and solution are the same. Remember, 63-70 was basically the same parts as far as steering and suspension pieces go.
CLICK HERE FOR THE OTHER THREAD
CLICK HERE FOR THE CPP WEBPAGE THAT SELLS THE SPECIAL SLEEVES
and here is the part number and description:
CP4SC Custom Tie Rod Adjusting Sleeve, Pair $49.00
Old 11-14-2004, 01:23 PM   #10
Sweet72
Sweet72's Avatar
That's a much easier and cheaper solution Tex. Didn't realize they sold anything like that.
Old 11-14-2004, 06:21 PM   #11
JPSAUTO
Thanks for the research Tx, looks like the easiest solution.
Old 11-14-2004, 07:17 PM   #12
lolife99
67-72 parts collector,…
lolife99's Avatar
Make sure you use '73-up ball joints with those spindles. They are different.
Keith
Convert to disc brakes.
