Old 06-28-2002, 01:41 AM   #1
72sleeper
[]D [] []v[] []D
no oil pressure help!!!!!!!!!
i run synthetic and i just changed my oil but i haveno pressure my dad swears it ismy valves btut hes adjusted them a billion times and i dont know what to do when i brake the pressure goes all the way down it doesnt even want to idle in neutral ??????? anyhelp thanx
Clint
72 c'10 350ci/400hp
sleeper forever
72sleeper is offline   Reply With Quote
Old 06-28-2002, 01:45 AM   #2
68 Suburban
68 Suburban's Avatar
I see no reason why synthetic oil would make your preasure go down. Could it be a bad oil filter? That happen to me once.
Just sitting here contemplating contemplation.
68 Suburban is offline   Reply With Quote
Old 06-28-2002, 03:36 AM   #3
Ed ke6bnl
Re: no oil pressure help!!!!!!!!!
Could be the sending unit mine was pluged and the reading was wrong. the wire could have come off also. Ed ke6bnl
Ed ke6bnl
Agua Dulce
70 S.E. Los Angeles
70 Chevy short bed
1948 F3 ford pu
1949 F1 stock V8 flathead 3 on floor
1950 F1 pu street rod
1948 F6 Ford Dually/350sbc no bed stock trans&rear
1972 El Camino 4" chop
1953 Chevy 3100 2b daily driver
1970 SB 4X4 400ci 6in lift
Ed ke6bnl is offline   Reply With Quote
Old 06-28-2002, 04:27 AM   #4
68 Stepside
huh?
68 Stepside's Avatar
try replacing your oil filter, and I'd run regular dinosaur oil too, synthetic can drop pressure, I've seen it happen, and there might have been a topic on this board about it at one time as well.
TJ
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 06-28-2002, 06:30 AM   #5
Super Chevy
Super Chevy's Avatar
mabe try a thicker oil,for say 20w50,what do you have in it now?
Super Chevy is offline   Reply With Quote
Old 06-28-2002, 07:26 AM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I pretty much agree with the others here...go to dino oil, get some thicker stuff, check your guage, and plus... tell your dad that your valves will have absolutly zero effect on your oil bressure.
Old 06-28-2002, 07:59 AM   #7
Randy70C-10
Randy70C-10's Avatar
I agree with the bad filter, since it went down with the oil change, seems logical.
Randy70C-10 is offline   Reply With Quote
Old 06-28-2002, 08:19 AM   #8
Longhorn Man
It is true, oil filters will stop up the oil system sometimes, not common, but it happens.
Old 06-28-2002, 08:30 AM   #9
racedvl
racedvl's Avatar
Do what I do.......run a quart of 80w90!!!!
racedvl is offline   Reply With Quote
Old 06-28-2002, 10:32 AM   #10
bigjimzlll
bigjimzlll's Avatar
dont the oil filter mount have a by-pass? if it was a bad filter wouldnt the oil just by-pass the filter? I went with synthetic and it lowered the oil pressure, not as dramatically as you stated, but as it heated up it got worse. did you drop the pan? almost sounds like you moved the pickup.
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
http://67-72chevytrucks.com/vboard/payments.php
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 06-28-2002, 05:59 PM   #11
Longhorn Man
Yes, filter mount does have a bypass...but they don't always work. Seen a couple do this.
Interesting tidbit of info...
In later model chevy small blocks, (not sure of the years thoguh) the by-pass is actually in the filter, and not the block.
Old 06-28-2002, 06:35 PM   #12
runx68SWB
i too had my oil pressure drop a good 10-12 psi right after i put synthetic in the new engine but it is still well within acceptable readings.... i was thinking about going with 15W-50 next time instead of 10W-30.... i think it was thickness of the oil and not the fact that it is synthetic that dropped the pressure.... gave me a real good scare at first though.... always a heart stopper when you see that oil pressure gauge move downward LOL
runx68SWB is offline   Reply With Quote
Old 06-28-2002, 09:32 PM   #13
72sleeper
[]D [] []v[] []D
im runnin 10w30 and it was fine at first and now itll stay high when i first drive itfor the day but after about 2 minutes its all the waydown and i know the gauge is fine cause i can feel it stutterin
Clint
72 c'10 350ci/400hp
sleeper forever
