Old 11-18-2004, 02:57 AM   #1
69GMCCamper
Speakers
Because of the small amounts of space in our trucks I was wondering where you guys put your speakers. I am looking at putting one 3'' approx in each door vent. How do you guys that have them in your doors run the wires to the doors. Any pictures of speaker setups would be great. Thanks
69GMCCamper is offline   Reply With Quote
Old 11-18-2004, 03:03 AM   #2
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
I have a pair of 6x9s in the floor in enclosures,and a 10" sub under the seat.
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 11-18-2004, 04:10 AM   #3
2low72
I have 2 6x9's in the door then some tweets in the air vents....
2014 GMC Yukon XL (Wifey's)
2004 Chevy Silverado Crew Cab Z71
2low72 is offline   Reply With Quote
Old 11-18-2004, 05:03 AM   #4
GMCPaul
Thumbs up
If your going to cut your doors and install speakers you will want to get waterproof backers to enclose speakers back side and attach them to the inside of door with silicone around outer edge to waterproof them otherwise when it rains water will run down glass and enter the door then drip on your speakers and you'll end up replacing them every year or 2 when the speakers paper breaks down.
Pioneer sells speakers in angled cases I believe are called TSX-11 that fit great under the front edge of seat, or can be set right on top the dash due to the angle on backside of speaker they rest comfortably against the glass with front edge even with dash pad and if you route the wires through original speaker grill and leave them extra long when you go camping, fishing , etc.... you can then grab the speakers from off dash or under the seat and set them on the outside of the truck for better musical enjoyment outside the cab.
There are also several speakers available to upgrade the stock one in the stock mounting location. You can find those here
http://www.gmcpauls.com/stereo_equipment1.htm
You will also find on that page kick panels that accept speakers up to 6" in diameter that can be installed so you don't have to cut up your doors.
GMCPaul
GMCPaul is offline   Reply With Quote
Old 11-18-2004, 06:42 AM   #5
RON WOODGEARD
Resident Young Old Dude !
Two 6X9s in the Lower Door, Two 6"ers in the Kick panel speaker housings I got from Paul, Two 8" subs in housings behind the seats where the Gas tank used to be, And two tweeters on the dash. But I'm contemplating the Piller Housings for them..
RON WOODGEARD is offline   Reply With Quote
Old 11-18-2004, 08:08 AM   #6
5150
C10 Club Tennessee
5150's Avatar
Not to bust up the thread, but does anybody have any pics or ideas on putting speakers in the kick panels?
thanks
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 11-18-2004, 10:06 AM   #7
2low72
On my 68 I used to own, I cut the old original speaker frame and mounted 2 4inch speakers in it and mounted in the original location.
Old 11-18-2004, 10:17 AM   #8
GreyHoundSteve
I have 4 alpine 5 1/4 components. 2 are mounted in the door panel and 2 are in the kick panel. Im going to do some subs where the gas tank use to be. The door panels are still being molded so i probably wont have pic's for a week or so.
GreyHoundSteve is offline   Reply With Quote
Old 11-18-2004, 11:13 AM   #9
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Ive had them in the doors.And in the space between the back glass and door
(right in your ear).under the seat, in the lower cab corners.
sneakysnake is offline   Reply With Quote
Old 11-18-2004, 11:27 AM   #10
Custom_C5
thanks
You can make your own custom kick panels....
Custom_C5 is offline   Reply With Quote
Old 11-18-2004, 11:57 AM   #11
383 Stroker
383 Stroker's Avatar
I had some kick panels made for mine. I also had speaker panels made for behind the seat.
Video's of my Truck Racing
1967 C-10, 383ci Sbc, TH350, 3200 stall, 3.73 gear
383 Stroker is offline   Reply With Quote
Old 11-18-2004, 12:14 PM   #12
GreyHoundSteve
Ive seen the kickpanels with speakers for sale by a few of the board vendors but i dont care for the looks of them. I had mine custom molded like the poster above.
Old 11-18-2004, 12:26 PM   #13
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
i have 2 six-9s under the seat. and 2 3 inch in the dash grill
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 11-18-2004, 02:30 PM   #14
RON WOODGEARD
Like this !!??
Kick panel speakers. You can buy them with different brands of speakers in them, or without speakers altogether.
Old 11-18-2004, 03:09 PM   #15
Hooter
My other Love
Hooter's Avatar
I haveMb quart 5 14 mids and tweets. mounted the mids in the doors, and Im reflecting the tweeters off the windshield, I should have mounted the tweeters way lower , because they don't image that well when the tweeter is so far away from the midbass, but I was thinking more on longgevity then soundquality when I mounted them. I also made two custom ported enclosures for AVI 6.5 inch subs that fit right under the bench seat, then I had an old school Kenwood 4 channel amp and a panasonic deck to run everything.
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 11-18-2004, 04:05 PM   #16
GreyHoundSteve
I loved mb quarts! I use to have 4 quarts 6 1/2 components and 3 jl w6 10"s in my supra and that system rocked. I was going to go with quarts again because they were so great but then i found out a friend of mine became an authorized Alpine dealer and i couldnt pass up his discounted prices. If i were going to pay retail or buy off ebay i would have gone with mb quarts. They make those components that mount the tweeter infront of the woofer on an arm and so you dont have the problem with the tweet mouting like you ran into.
Its NEVER a good idea to seperate your components by more than a few inches.
With my new Alpines i decided to only use 2 of the 4 tweeters because there so bright.
My cab is getting the metal work done today and the guys said it should be in paint no later than Wednesday and then i can begin to insolate and install most of the interior.
Old 11-18-2004, 04:23 PM   #17
Super Duck
Chevy Nuttttt
Super Duck's Avatar
how about infinity? I am personaly a fan. My truck is curently running a pair of 6x9s in a console, but will be going with a set of kick panels and boxes behind the seat to put the speakers twards the top of the seat
67' Chev swb step side
69' SS elky
03' Chev ext cab 4X4
hey who lernt me to spell
is there anything else?
Super Duck is offline   Reply With Quote
Old 11-18-2004, 05:02 PM   #18
Hooter
My other Love
Hooter's Avatar
I love infinity too,we sell Infinity, JBL, Pioneer, MBquart, Pheonix gold, sony and alpine, and the infinity's are one of our best selling lines, plus I like the aimable tweeters on the coaxials. Are you going to move those 6x9's out of the console? because for imaging the best solution in these trucks for s.q is the kick panels, personally i find no point in having sound come from behind me, have good enough front speakers and you will never miss those back speakers
pictures of my life
Old 11-18-2004, 05:29 PM   #19
Super Duck
Chevy Nuttttt
Super Duck's Avatar
my friend and i messed around with speeker placement and came up with the best sound this way. that and i am tired of kicking them.
69' SS elky
Old 11-18-2004, 06:42 PM   #20
68w/sbc406
68w/sbc406's Avatar
have you guys heard of polk??? my friend has some speakers he wants to sell me, but i havent heard of them(not a big stereo guy)
Old 11-18-2004, 06:52 PM   #21
GreyHoundSteve
I have polk audio pro series in my home theatre and they rock but im not familiar with their mobile line. Polk is a big company so as a rule of thumb with large manufactures is that they make a budget line that usually sucks and a top of the line that usually rocks so i would get the #'s off those particular speakers and do a search and see what you can find.
Old 11-18-2004, 07:06 PM   #22
68w/sbc406
68w/sbc406's Avatar
coo, thanks
Old 11-18-2004, 07:14 PM   #23
longnlow72
longnlow72's Avatar
i put 6x9's in the doors, two 4's under the dash, and two 10's and an amp under the seat
72 Chevy lwb, cowl hood, shaved antenna, shaved bedrails, blazer tank, sidemarker fill, 1pc windows, flowmaster 40's, alpine deck, infinity 6x9's, infinity 4"ers, 2 jl audio 10w0's, grant wheel, keyless entry and alarm, more waiting to be done...
longnlow72 is offline   Reply With Quote
Old 11-18-2004, 07:29 PM   #24
TugOwar
I might spend alot of money on sterio equipment. . . IF I could figure out how to hear my exhaust through the speakers!
TugOwar is offline   Reply With Quote
Old 11-18-2004, 08:10 PM   #25
RON WOODGEARD
I have 6X9 MBQuarts in The door panels that I didn't have in when I took the Pictures. I still have the Blaupunkt 6" in the Kick Panels, But I will put MB Quarts in there also, and I'll put JL Subs instead of whatever I have now.. my Tweeters are Infinity, I will also change them over to MB Quarts..( I will go Components ) The 6X9s made a Tremendous Difference in the sound Quality.. I have had throughout the years, just about every Speaker made, The MBQuarts out do them hands down....
