Old 11-19-2004, 08:50 PM   #1
roadstar
Question 4 Core Radiator Install Problem
Got a 67 that started life with a I6 which I swapped to a 305. Finally got around to putting in a 4 core radiator. Problem is that it sticks up too tall for the top mount brackets to bolt down flush on the frame without using a spacer of about 1/2 inch. I did the following:
1) New 4 core upper & lower radiator mount brackets and rubbers.
2) Notched the back of the radiator mount pan so that the wider 4 core brackets will seat down flush.
The radiator is from Autozone and I have cross checked the part number and it is the one that everyone seems to list for this application. I believe the part number reference is GM 43-3369 if memory serves me right.
Anyone run across this problem or give me a hint to what I did / didn't do ??
Thanks in advance!!
2002 Chevy Blazer
1967 Chevy Stepside
2002 Yamaha Roadstar
roadstar is offline   Reply With Quote
Old 11-19-2004, 10:24 PM   #2
da-burb
"Ochre Ogre"
da-burb's Avatar
Measure the height of your old side tanks and compare to the new radiator. My guess is they are the same. The difference is the rubber mounts for your 4 core might be new and they need a little more oompf to compress them. I have installed radiators that had the upper brackets a 1/2" above the rad support. It still bolted in nice and snug without any problems.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 11-19-2004, 10:56 PM   #3
RODSBYT
RODSBYT's Avatar
I had to trim the back of the rubber pads too. I think the repo pads are thicker and denser than the originals. I have had it in about a year with no problems.
RODSBYT is offline   Reply With Quote
Old 11-20-2004, 02:04 AM   #4
roger0080
Like Da Burb says. With new rubber it does that. It will compress down and look normal (eventually).
72 Chev C-10 90% restored (former AZ truck) ...
71 Chev K-20 Cheyenne my vacation crusier...
72 Chev C-10 Now retired and striped after many faithful miles...
72 GMC 1500 Retired to the junk yard after bought new in '71...
roger0080 is offline   Reply With Quote
