Old 11-22-2004, 11:45 PM   #1
RODSBYT
RODSBYT's Avatar
Front bump stops on lowered trucks
What are you guys doing with your front rubber bumpstops with lowered springs?
I have early classic 2 1/2 spindle with 1 1/2 drop spring.
Will trimming the bump stops down for more travel cause bump steer???
Thanks for the help.
RODSBYT is offline   Reply With Quote
Old 11-23-2004, 01:43 AM   #2
68327stepside
I just put in a set of energy suspension bump stops that are a little bit shorter and I have almost the exact set up as you. Works great.
USMC "Pray for peace, train for war"
(The Beast) 68SWB Stepside Original 325hp/327 3:73 Posi Lowered 3.5/4.5
68327stepside is offline   Reply With Quote
Old 11-23-2004, 08:02 AM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Trim them if you'd like or remove them completely. I've done both ways.
Bumpsteer is caused by improper geometry in the suspension, it has nothing to do with the bump stops. It's caused by the relationship between the steering linkage and the suspension components being altered (or improper to start with).
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 11-23-2004, 01:04 PM   #4
Randy70C-10
Randy70C-10's Avatar
I removed mine and grinded the metal mounts off as well.
Randy70C-10 is offline   Reply With Quote
