11-24-2004, 10:14 AM | #1 |
I6 vs V8 4x4 engine crossmember ???
Does anyone know if a I6 4x4 engine crossmember is the same as a V8 4x4 crossmember. The truck currently has a 292 I6 in it and I want to put in a 350 V8. Can I just move the crossmember to the V8 location or do I have to get a different crossmember ?? ( It's a 1970 )
Gary Last edited by CUSTOM/10; 11-24-2004 at 10:21 AM. |
11-24-2004, 10:22 AM | #2 |
I don't know but here are a couple pics of my small block V8 crossmember in my 69 K20. Hope they help you.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
11-24-2004, 10:27 AM | #3 |
Resident Curmudgeon
Gary, that 292 xmember is definately different. I have a v8 unit if you need it...as partial trade?
I should add it is differtent because of the offset mounts used on the 292. If you look at it you'll see the rh side mount is forward of the lh side mount. Isn't it funny I plan on deepsixing (pun intended) my 350 for a 292 in my 4x4
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
11-24-2004, 10:41 AM | #4 |
Crossmember
Jeff
Sure we can work out a partial trade. Hey I found the original papper work from fisher in the glove box, it shows an illustration of the pump bracket & pulleys but not installed. Down the road, when I take the 292 out would you be interested in it ??? Gary Thanks Yukon, but it sounds like Jeff knows for sure. Last edited by CUSTOM/10; 11-24-2004 at 10:44 AM. |
11-24-2004, 10:46 AM | #5 |
Resident Curmudgeon
Got one , but if it's dirt cheap...
I'll get that xmember removed in anticipation of trade...real cool on the fisher docs
