Old 11-26-2004, 04:45 PM   #1
dinnut
dinnut's Avatar
my truck after drop (updated pics)
heres some pics of truck after i lowered it 2.5 inches in the front and 4 in the rear. stock shocks. new frontend. i also put new exhaust on it but damaged the passenger side already...truck has a rebuilt th350 now and we just put an edelbrock performer rpm with a holley 600 cfm carb on it. i had a nice polished 105 amp alternator but faulty wiring messed it up ALREADY. im pissed and hoping i can order a kit to fix it. i had to fix all the wiring goto the alternator until i get my new front lightsharness in. i also put a 275/60/15 dunlop g/t qualifier on the back of the truck. still 255/60 on the front. im going to get matching tires front and rear eventually. im sticking with a 255/60 dunlop g/t qualifier on the front when i get them. the interior is up next with new floors, sound deadner, carpet, then i get my system installed. 2 12's are going behind the seat where the gas tank used to be. oh the ghetto filler neck door and cab patch will be fixed when i save up and have the body work done to them...
and i have two reproduction goodmark doors waiting to go on after i do the floors and rockers...
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 11-26-2004, 04:48 PM   #2
dinnut
dinnut's Avatar
heres a before pic of the truck and what the engine looks like now
70 longbed
496/th400/Ford 9"
Old 11-26-2004, 04:51 PM   #3
Sweet72
Sweet72's Avatar
Looking real nice so far. What wheels are those?
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 11-26-2004, 05:01 PM   #4
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Looks good dinnut did you finally get the wheels to stay on the truck?if so what was the problem???
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 11-26-2004, 05:02 PM   #5
dinnut
dinnut's Avatar
no idea on the wheels. yeah havent had any problems so far. i think the lugs on that wheel might have been left loose for some reason. or it could be that that wheel had a horrible wobble to it because the front end on that side was in horrible need of replacement and might have vibrated them loose. i have all new lugs now and i make sure they are tight.
70 longbed
496/th400/Ford 9"
Old 11-26-2004, 06:04 PM   #6
Randy70C-10
Randy70C-10's Avatar
Nice truck!!
Randy70C-10 is offline   Reply With Quote
Old 11-26-2004, 07:32 PM   #7
Yukon Jack
Yukon Jack's Avatar
Looks real good!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 11-26-2004, 07:48 PM   #8
john@thepier
john@thepier's Avatar
How do you like the drop so far,and would you go more next time? I'm planning to drop my first truck soon,and have not decided how much yet.
john@thepier is offline   Reply With Quote
Old 11-26-2004, 08:37 PM   #9
Wootdog
Wootdog's Avatar
Nice truck
Good looking truck. It makes the rest of us get motivated to do things to ours. Keep up the good work. Kerry
1967 C10
Got it back after three years
Boy I sure missed Peppy
1969 Chevelle
1990 IROC Z Convertible
2002 Silverado LT
Wootdog is offline   Reply With Quote
Old 11-27-2004, 12:50 AM   #10
dinnut
dinnut's Avatar
i love the drop. especially with the bigger tires in the back. if i wanted to go any lower i would look into bagging it or getting new wheels. my current wheels would hit the fender and bedside if i tried to lower it more. also i would have to purchase more parts such as shock relocators and an adjustable panhard bar. im very pleased with it right now. i used springs front and rear
70 longbed
496/th400/Ford 9"
Old 11-27-2004, 01:18 AM   #11
70c10
67-72 Addict!
70c10's Avatar
That stance looks perfect for me. Where did you get your lowering coils?.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 11-27-2004, 01:33 AM   #12
dinnut
dinnut's Avatar
the front coils came from gmc pauls and the rears came from outback truck parts (local place up in spring, tx) im still running the stock shocks
70 longbed
496/th400/Ford 9"
Old 11-27-2004, 01:39 AM   #13
70c10
67-72 Addict!
70c10's Avatar
Does it feel like you will need shock relocators or drop shocks or is it too soon to tell?. That is a huge improvemnet in that stance!
Jim
Old 11-27-2004, 01:55 AM   #14
dinnut
dinnut's Avatar
honestly i have no idea! eventually i would like to buy some kyb drop shocks and possibly relocate the shocks. it rides pretty well like it is though
70 longbed
496/th400/Ford 9"
Old 11-27-2004, 02:09 PM   #15
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Dude, that passengers side door would look great on my truck. It would match perfectly.
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 11-27-2004, 08:55 PM   #16
Deuce
Deuce's Avatar
What kind of shifter are you using?? I love it!!
I know what your thinking.......I have ESPN.
Sometimes it's easier to do things the hard way.
Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!!
Deuce is offline   Reply With Quote
Old 11-27-2004, 09:00 PM   #17
Truck looking real good Dinnut. It has a very nice stance to it, of course I like the stance before too!
Palf70Step is online now   Reply With Quote
Old 11-27-2004, 09:01 PM   #18
dinnut
dinnut's Avatar
the truck is an automatic. just to let you know. the shifter is a lokar piece. i love it. once i get the boot and everything on it will look even better. the shifter is the lokar hot rod curve one. http://www.lokar.com/ i really need to get the clutch pedal out of the truck to stop confusing people
70 longbed
496/th400/Ford 9"
Old 11-27-2004, 09:11 PM   #19
Deuce
Deuce's Avatar
I knew it was a auto shifter. Wasn't sure if it was a Lokar though. How do you like it??
Old 11-27-2004, 09:16 PM   #20
dinnut
dinnut's Avatar
i love it. its a little bit interesting to install with the tranny still in the vehicle though... the first time we installed it we got lucky and i had a big hole in the floor from my old shifter and that made things easier.... other than that it is great!
70 longbed
496/th400/Ford 9"
Old 11-27-2004, 09:18 PM   #21
Deuce
Deuce's Avatar
Can you install it on a tranny already in the truck??
Old 11-27-2004, 10:14 PM   #22
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
they just clamp on to the tranny except for two bolts that you have to pull out of the tail to bolt it on. do you like it that tall??? i got a shorter one and i love it. get lots of complements.
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 11-27-2004, 11:55 PM   #23
weasel29gm
SLOW BUT SURE,BUT CLOSER
Lookin' great!!!!!!!
69 C-10, OWNED 38YRS... 350 over 30, 350 Turbo, 3:73 Posi P/S, P/B Black with red and black int. ''LOVE THESE OLD ''TRUCKS.......
weasel29gm is offline   Reply With Quote
Old 11-28-2004, 12:09 AM   #24
sixty8c10
MY EX DRIVES A BROOM
sixty8c10's Avatar
68w/sbc406,
where did youet the cup holders, and how did you install them?
They say nobody's perfect.
I'm a nobody, so I must be perfect.
Building Nemo -1968 C10 Long Bed
FRED -1947 KB-2 International
sixty8c10 is offline   Reply With Quote
Old 11-28-2004, 01:37 AM   #25
dinnut
dinnut's Avatar
maybe its just the way my truck is setup but it was a pain to get all that lined up and bolted in....
70 longbed
496/th400/Ford 9"
