Old 11-27-2004, 01:21 AM   #1
hotrodtroy
hotrodtroy's Avatar
Brake booster addition
Right now I only have manual brakes and I'm thinking about adding a booster but not too sure about how to go about getting that done. Right now It's disks/drums so the prop valve is good and so is the m/c. Any help would be appreciated. Thanks, Troy
'72 C-10 w/
'68 Large Journal 327cu.in.
"It's o.k. to dream about what you want to do, until you start doing what you are meant to do." Line from "The Rookie"
hotrodtroy is offline   Reply With Quote
Old 11-27-2004, 01:54 AM   #2
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
you can just unbolt the master cylinder pull it forward and bolt the booster on the then the master on. you will have to bend the lines alittle but they work. and you need a rod that goes in between the pedal and the booster.
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 11-27-2004, 02:02 AM   #3
68LSS1
68LSS1's Avatar
And you'll have to get the bracket as that won't come with a new booster. If you get one off a donor make sure you get it then.
'68 Short Step
LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc
68LSS1 is offline   Reply With Quote
Old 11-27-2004, 04:36 AM   #4
toddtheodd
The oddest Todd around
toddtheodd's Avatar
And you might as well get a booster from a 3/4 ton. I have heard that they make the brakes a whole lot better.
toddtheodd is offline   Reply With Quote
Old 11-27-2004, 08:10 AM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Troy, if you do a search on this board under "booster" and my name, you'll find plenty of details and pictures of the installation.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 11-27-2004, 08:17 AM   #6
Tx Firefighter
HERE ,HERE ,HERE , and HERE should get you started with some light reading.
There's plenty of pictures in those threads to clear up any questions you may have too.
Old 11-27-2004, 04:00 PM   #7
hotrodtroy
hotrodtroy's Avatar
Thanks Guys,
Troy
'72 C-10 w/
