Old 06-30-2002, 05:20 PM   #1
69GMC910
MOTORHEAD!
69GMC910's Avatar
Question Torque'n the heads RIGHT NOW!!!! Need help ASAP!!!
I'm currently installing heads on the 350, finally switching the 305 heads to 350 ones. What should all the bolts be torqued to? I am using the old bolts again, do I have to torque them higher because of threads stretching?
What is the procedure for tightening the rockers, are they all at a specific torque?
Also, My pistons have stamped on them 345NP .030 So I know its 30 over, does anyone recognize the 345NP? They are a flat top piston but I would like to know the compression ratio.
Thanks for the help
P.S. I really like the new board!!
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Performer RPM Air Gap
Hooker 2455's
TCI Turbo 400 Super Street Fighter
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Hoosier 30x10.5 Radial Slick
Full weight long box pickup
Current best- 11.33@117mph
69GMC910 is offline   Reply With Quote
Old 06-30-2002, 05:27 PM   #2
bigvinnie
bigvinnie's Avatar
70 ft. lbs. on the head bolts.... go thru the order, working from the center bolts out, first torquing all to 30 ft lbs, then do a second pass, torquing to 70...
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA
72 Stepside Project
bigvinnie is offline   Reply With Quote
Old 06-30-2002, 05:59 PM   #3
69GMC910
MOTORHEAD!
69GMC910's Avatar
Thanks Bigvinnie.
Anybodt know the torques on the Rockers???
Need help right away!!!!!
Thanks again!
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Hooker 2455's
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Old 06-30-2002, 06:00 PM   #4
fluffytx1
fluffytx1's Avatar
compression ratio answer
there are alot of ways to find compression ratios. You need to know some things first though. Most heads gives you head chamber volume and pistons do to (the number on your piston is the volume in cubic centimeters) head gasket specs: most head gasket co. list specs thicker head gaskets and bigger bores gives lower compression ratios.
go into these links to find a formula that will calculate your compression ratio with the above info.
www.mindspring.com/~steveflyer/compression.htm
www.smokemup.com/utilities/calc/compression.raatio.cfm
scott
1968 GMC CST long wide box
http://groups.yahoo.com/group/67-72-collectors/
fluffytx1 is offline   Reply With Quote
Old 06-30-2002, 06:23 PM   #5
bigvinnie
bigvinnie's Avatar
If you're talking about adjusting the rocker arms, torque isn't really part of the equation.... you adjust each one individually for valve lash and you're done...
here's a decent link for adjusting valves...
http://www.camaros.net/techref/ftecref17.html
72 Stepside Project
