Old 11-27-2004, 11:28 PM   #1
griesel72
griesel72's Avatar
Quick HEI swap question
I just want to make sure i am correct on this, to add HEI to a truck that has always had points, i do not have to do anything with the oil pump intermediate shaft?
And all i have to do is add a wire to the unfused port, and clip the yellow wire off the starter/old dist?
thanks
David
1969 K10 Custom 10
1997 Z71
2006 Volkswagen Jetta TDI
2006 King Ranch
1980 Wife
griesel72 is offline   Reply With Quote
Old 11-27-2004, 11:50 PM   #2
kwmech
Oil pump drive remains the same
Old 11-27-2004, 11:52 PM   #3
griesel72
griesel72's Avatar
I thought that was correct, but just wanted a second opionion.
thanks
DAvid
1969 K10 Custom 10
1997 Z71
2006 King Ranch
1980 Wife
Old 11-27-2004, 11:54 PM   #4
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
That's all! Or, if you really wanted to be slick, you could remove the resistor wire from the plug at the firewall and replace it with a 12g wire. I just did this on my 70 4x4. Grab the terminal with a pair of needle nose pliers so the terminal gets pinched together, as to close the gap. Then push it out. It is even better if you have an old harness that could donate another wire and ternimal from.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 11-28-2004, 12:36 AM   #5
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I just hooked up hei in my 69 today.. Used some wire from the fuse box to the dizzy and removed the yellow wire from the starter..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
