Old 11-29-2004, 03:11 PM   #1
Mike Culpepper
Red
Mike Culpepper's Avatar
Battery or alternator?
This morning (and for the third time this month) I went to start my 72 and NOTHIN' no lights or sound or anything---dead. After last time I recharged the batt and it tested o.k. , today I had the alternator tested and it tested o.k.? Each time the truck had set for 2-3 days withought being driven. Each time after recharging, the truck started easily, and did so the rest of the week---- daily driver. I haven't added anything electrical or changed anything. The guy at NAPA, said that even though the alt. tested good it could be drawing down the battery over those two days. What do ya'll think? I CAN replace both, would prefer to replace just the culprit though. The battery is a Duralast and IS 6 yr. old. I cleaned the posts(which were not bad) this a.m. and still nothin.
Mike
'72 Cheyenne LWB 350/350
"The sun don't shine on the same dog's ass all the time." - Catfish Hunter (commenting on why he was not able to pitch another perfect game).
Mike Culpepper is offline   Reply With Quote
Old 11-29-2004, 03:30 PM   #2
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
With a charged battery, pull the neg. cable off use a test light or bulb (not a meter it will read though the diods). place the bulb(series) between the post and wire if there is a drain the bulb will glow.Be sure to have everything off and doors closed. If it does glow pull the wires on the alt. that will eliminate it.If it doesnt glow then you may have a bad cell in your battery draining it down but a load test will usually detect this.
sneakysnake is offline   Reply With Quote
Old 11-29-2004, 03:36 PM   #3
Super Duck
Chevy Nuttttt
Super Duck's Avatar
the other thing to look at while doing that test is if the light does come on pull one fuse at a time and when it goes out you have found the syst with a draw.(short)
67' Chev swb step side
69' SS elky
03' Chev ext cab 4X4
hey who lernt me to spell
is there anything else?
Super Duck is offline   Reply With Quote
Old 11-29-2004, 04:07 PM   #4
Mike Culpepper
Red
sneakysnake,
which wire? Should I check both wires on the alt. one at a time? Since I don't always have a firm grasp on the obvious..... I should use a test light with one end hooked to the neg. battery post and the other touching one of the two wires going into the alternator, and if the alternator is draining the battery, the test light should light, correct? THen check the other wire going into the alternator.
Mike
Old 11-29-2004, 04:10 PM   #5
Mike Culpepper
Red
Super Duck,
IF the test bulb lights as described abouve, then the draw COULD be any electrical component? And to test this is where I would pull one fuse at a time, Correct?
Mike
Old 11-29-2004, 04:16 PM   #6
Super Duck
Chevy Nuttttt
Super Duck's Avatar
corect. if there is a draw on the system you will find it. then have fun finding the prob from there. it will mean shooting wires. if you are lucky it will be a switch for the glove box light or a cig lighter.
69' SS elky
Old 11-29-2004, 04:44 PM   #7
Mike Culpepper
Red
Thanks to both of ya'll
Mike
Old 11-29-2004, 04:58 PM   #8
Super Duck
Chevy Nuttttt
Super Duck's Avatar
let me know what you find
69' SS elky
Old 11-29-2004, 05:15 PM   #9
da-burb
"Ochre Ogre"
da-burb's Avatar
If your horn doesn't work start there! The horn relay is stuck on and I'll tell you right now that it just happens to be a 2-3 day battery drain. It happens so often that it has become the first place I look.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 11-29-2004, 05:30 PM   #10
Super Duck
Chevy Nuttttt
Super Duck's Avatar
good call. difrent vehicle types have there own querks
69' SS elky
Old 11-29-2004, 07:44 PM   #11
sneakysnake
Originally Posted by Mike Culpepper
sneakysnake,
Mike
the test light goes between the battery post and the wire that goes to that post(by unhooking the neg.wire from the battery, make all the electricty go though the bulb)
Old 11-29-2004, 09:56 PM   #12
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
There is a pic of this and detailed instructions in the FAQ section.
Old 11-29-2004, 09:58 PM   #13
kwmech
Personally if I had a battery that was 6 years old and began to give me any kind of problem, I would replace it.
Old 12-13-2004, 11:06 AM   #14
Mike Culpepper
Red
Sorry, I didn't see these last couple posts. I will look in the FAQ section, and I did replace the batt. just coz it was so old.
Thanks again
Mike
