Old 07-01-2002, 03:43 PM   #1
jones
Question where to buy - VACUUM SWITCH
Please help. I'm wondering where to buy a
Vacuum distribution switch/valve. (it's the one that mounts to the top of the heater/AC controls and controls vacuum to the different air doors)
mine was ruined when the heater shut-off valve (in line on heater hose) failed and sent coolant through the vacuum line to the switch/valve. the local parts stores can't get one. the dealer says it was discontinued in 1985. LMC, Golden, Harmons and others say they don't have one either.
so far, the only way I've found to get one is by buying the entire control assembly for $130-$180!
PLEASE ADVISE
thanks in advance
jones is offline   Reply With Quote
Old 07-01-2002, 08:22 PM   #2
jones
ttt - please. it's over 100 degrees & I need AC
Old 07-01-2002, 11:05 PM   #3
70c10
67-72 Addict!
70c10's Avatar
Cool
Looks like you'll have to suffer like the rest of us, LOL. Try www.gmcpauls.com , he might have it. Good luck
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 07-11-2002, 01:36 PM   #4
Woody
I need one of these also, So someone plaese help!!!
There is a GM p/n on the switch so GM may be able to get one. My truck isn't running right now so it has not been a priority for me.
Woody is offline   Reply With Quote
Old 07-11-2002, 02:56 PM   #5
tom hand
CCRider
tom hand's Avatar
That switch only operates the heater control valve and the fresh air control. Both can easily be bypassed if it is hot outside, so there is no reason not to enjoy your A/C till you find one.
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 07-11-2002, 08:17 PM   #6
jones
Arrow
right you are, tom hand. you can manually apply vacuum to the heater valve and/or the 2 air doors if you want full-time 'recirc'.
I got a used one from...
http://s-c-t-p.com/
for $2. it only had 2 vacuum nipples while my switch had the elusive "third nipple". so I tee'd the hose to the heater valve in with the air door hose. we'll see...
J
