Old 12-03-2004, 05:17 PM   #26
jhow66
jhow66's Avatar
Also check 20Pink (fuel gauge feed) & 20DarkGreen (temp gauge feed) where it enters fuse panel. Remove 2 screws and fuse panel will come off wall. Sound like these 2 wires have melted on to a hot wire(red) when something has shorted out.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 12-03-2004, 06:05 PM   #27
chickenwing
Lovin' Life in Miss.!
chickenwing's Avatar
I more thing. The 2 accessory taps below the fuse.... Pull those 2 connectors and make sure THEY are not feeding the power.
The truck... you hear that? No really, you did hear that?!!!
chickenwing is offline   Reply With Quote
Old 12-04-2004, 10:07 AM   #28
68speedalert
Semi-Senior Member
68speedalert's Avatar
As chickenwing stated, there shouldn't be any fire with the key off at the gauges. Disconnect the connector fron the ign switch, If the draw goes away,(and I think it will) your ignition switch is bad. PERIOD. Don't check anything else until you do this.
'68 50th Anniversery LWB Custom Fleetside, '77 305 v-8, turbo 350, factory speed alert (still works), '71 drivetrain w/front discs. Some call it ugly yellow, others call it Ochre
'83 Jeep CJ-7, <80,000 miles, original owner
'04 Chevy Suburban, 4x4, 2500, 6.0 ltr, Predator Diablo programmer
'95 GMC K1500 Extended cab
68speedalert is offline   Reply With Quote
Old 12-04-2004, 12:05 PM   #29
jorgensensc
jorgensensc's Avatar
O.K.
update,
I put the truck back together last night, not feeling to great about anything. Drove her around quite a bit, then came home. While I was driving around my temp gauge went out on me.. hmmmm. At least I think it did, it pegged all the way to hot, and I know the truck wasn't running hot. I went out there this morning to see if she would fire up (usually she won't after a night of sitting) and she fired right up. Nice and strong. I wonder if the temp gauge either was a problem, or something running through it was a problem and when it went out it broke some kind of connection. So, the problem still isn't fixed, but it will work for the moment I guess.
68speedalert,
I had already pulled the switch and all wires and still had a draw. I shouldn't have I know, but I did.
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 12-04-2004, 04:30 PM   #30
68speedalert
Semi-Senior Member
Something is bleeding over to your gauge circuit for it to be causing the drain. Have you done any rewireing or adding of any electrical lately?
Old 12-05-2004, 01:39 AM   #31
chickenwing
I think post #18 and #27 is still the way to go.
