Old 12-05-2004, 04:46 PM   #1
ronsk10
column shifter removal
how do you remove the shifter arm. I just installed a megashifter and would like to remove the stock column arm. Thanks
ronsk10 is offline   Reply With Quote
Old 12-05-2004, 05:08 PM   #2
72_Chev_Truck
well if you want to just remove the arm, take a small punch and tap out the pin with a hammer, otherwise to remove the whole assembly on the column you have to take off the steering wheel, turn signal switch, then remove the piece that attatches the arm and replace it with one off of a manual truck
72_Chev_Truck is offline   Reply With Quote
