12-08-2004, 10:23 PM | #1 |
Wtb: Column Shift Linkage
LOOKING FOR 'ALL' THE NECESSARY LINKAGE TO HOOK UP STOCK SHIFTER FROM COLUMN TO TRANS (3spd MANUAL V8 1972). I HAVE A SHIFTER COLUMN THAT HAS HAD LINKAGE REMOVED. ALSO NEED SHIFT ARM.
THANK YOU! Last edited by CARS4567; 12-09-2004 at 07:45 PM. |
12-08-2004, 10:55 PM | #2 |
I have everything you need from the trans up to the firewall hookup $35 plus the ride
12-08-2004, 11:08 PM | #3 |
shifter
I will pm you-thank you
12-08-2004, 11:29 PM | #4 |
"Trucks with Class"
Which trans?
They are different: TH400 vs TH350.
If you are looking at used, be careful of worn out/sloppy parts. I use & sell a nice kit that replaces all of that old GM stuff with stainless. It looks better and gives more clearance. When you come down for those GMC caps, I will show you. |
12-09-2004, 12:00 AM | #5 |
shifter parts
thank you Frank...will do!
12-09-2004, 07:37 PM | #6 |
Shift Linkage
I WAS NOT 'CLEAR' ABOUT THE TRANSMISSION IN THIS TRUCK....IT IS A 1972 W/307 AND A 3sPD MANUAL .
THANKS AGAIN FOR ALL THE HELP! Last edited by CARS4567; 12-09-2004 at 07:45 PM. |
12-10-2004, 10:28 AM | #7 |
Shifter
Ttt
