Old 07-02-2002, 05:06 PM   #1
Yukon Jack
Yukon Jack's Avatar
Pulling distributor
I'm considering pulling the old distributor and replacing it with an HEI unit. My spark plug wires are chewed up by rats and it's time to replace them anyway.
When I was looking at my engine this morning it doesn't look like the distributor could be pulled up and out without hitting the firewall above the distributor. My engine is a 307 and it is in my 4x4.
This pic doesn't show the potential problem too well, but maybe you can see the problem.
Anyone have a similar problem? If so, what was your solution?
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 07-02-2002, 05:09 PM   #2
chevy2racr
So Many Ideas, So Little Money
chevy2racr's Avatar
I was able to pull my HEI on my 327 I pulled the cap first, then the dist. try that if it won't come wiht the cap on
Bryce
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors
71 C10 with 454
99 S-10 5.1L SBC 700R4
09 Malibu
Marshalltown, Iowa
chevy2racr is offline   Reply With Quote
Old 07-02-2002, 05:18 PM   #3
johnnyp
Keepin' It Stock
johnnyp's Avatar
If you can't get it out, you might consider going with the PerTronix Ignitor
72 Sierra Grande - Maych
Forget about "do it right the first time". Do it wrong the first time to learn how, then do it right the second time.
johnnyp is offline   Reply With Quote
Old 07-02-2002, 05:19 PM   #4
barn9
Half a bubble off!
barn9's Avatar
Have you got the HEI yet? I got mine off of a wrecked Trans Am that had just been pulled into the local bone yard, so it's worth a try. You know I'm mechanically challenged, so I had a mechanic friend help with the changeover. Jason has probably done a couple. Did you get your tranny changed yet?
I will PM you another question I want to ask you, off topic, so no need to put it on here.
Let me know if you need some help.
Just call me LB.
'71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads.
barn9 is offline   Reply With Quote
Old 07-02-2002, 07:15 PM   #5
junkyardjohn
junkyardjohn's Avatar
Thumbs up
IT'LL COME OUT. HONEST . ALTHOUGH IT DOESN'T HAVE ALOT OF EXTRA ROOM, & YOU HAVE TO REMOVE THE CAP FIRST, IT WILL COME OUT.
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 07-02-2002, 08:46 PM   #6
68 Stepside
huh?
68 Stepside's Avatar
Being a 4x4, the engine sits in the rear motor mount position. So it will be an extremely tight fit. But if you take your old one out (be sure to mark the rotor location), and take the cap off of the HEI, it should drop in. Mine does, and my 406 is sitting in the rearward frame holes.
TJ
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 07-02-2002, 08:58 PM   #7
Gordo
Smile
My 350 is in the 6 location and the hei fits, it's close, about the thickness of my finger between the cap and firewall. Both distributors will slip out and in.
1971 C10 swb stepside 350/700R4/3.73posi (retired as of 4/22/03)
1998 S10 short bed
2002 S10 Blazer
1942 Oldsmobile
1958 Massey Harris Pony
1951 Wife
Killingworth, Connecticut
May those who love us, love us, any of those who do not love us, may God turn their hearts.
And if God is unable to turn their hearts, may he turn their ankles so we may know them by their limping.
A man who works with his hands is a laborer; a man who works with his hands and his brain is a craftsman; but a man who works with his hands and his brain and his heart is an artist.
Gordo is offline   Reply With Quote
Old 07-03-2002, 03:13 AM   #8
Ed ke6bnl
HEI
My boys truck engine is in the rear location but the truck came with the small cap dist from Mallory with a separate coil. Not a bad way to go. Lots of room. Ed ke6bnl
Ed ke6bnl
Agua Dulce
70 S.E. Los Angeles
70 Chevy short bed
1948 F3 ford pu
1949 F1 stock V8 flathead 3 on floor
1950 F1 pu street rod
1948 F6 Ford Dually/350sbc no bed stock trans&rear
1972 El Camino 4" chop
1953 Chevy 3100 2b daily driver
1970 SB 4X4 400ci 6in lift
Ed ke6bnl is offline   Reply With Quote
Old 07-03-2002, 08:52 AM   #9
junkyardjohn
Thumbs up
I'VE HAD THREE OF THESE TRUCKS THAT WERE 4WD, & THE MOTOPS ON ALL OF THEM SAT IN THE REAR FRAME HOLES. (6 CYL. LOCATION ON 2WDs) I THINK THAT MUST BE WHY THEY HAVE SUCH A BIG INDENTION, IN THE FIREWALL, & THE FAN SHROUDS ARE QUITE A BIT LONGER.
junkyardjohn
DON'T RENT U-HAUL
Old 07-03-2002, 08:56 AM   #10
RodC
RodC's Avatar
I have the PerTronix Ignitor. Works great and retains the stock appearance.
Rod Childers
'71 C10 Stepside
RodC is offline   Reply With Quote
Old 07-03-2002, 09:16 AM   #11
Yukon Jack
Yukon Jack's Avatar
Glad to hear it ought to come out. I don't really know how long the distributor is but it just looked really tight. Here are a couple more pics that show the clearance issue better.
BTW - The stuff that looks like a film of grease and goo on various parts of the engine is actually a high performance mixture that will take nearly 2 seconds off your 1/4 mile times. Its good stuff but highly confidential - for that reason, please do not download these pictures and post on Ford boards. The rat chew marks on the spark plug wires are also intentional - serious performance gains if placed in just the right position. :p
Old 07-03-2002, 09:17 AM   #12
Mike C
Mike C's Avatar
Mark, It will come out. It looks tight, but once you pull the cap and rotor, out it comes. A full size HEI won't fit with out some hammer massaging. I wasn't willing to go that route so my solution was an MSD ready-to-run billet distributor. Comes with cap and rotor for $240 or so. While more expensive than buying an aftermarket GM HEI, and WAY more expensive than the junkyard route, it is the more elegant way to go. Get yourself a Blaster II coil while you're at it for another $30. It will really make your truck start and drive better.
For all you 2 wheel drive guys, the 4x4 engine placement is similar to mounting a V8 on 6 cylinder stands. The distributor is about 1" from the firewall, actually inside the recess. This was done in order to keep a reasonable length on the front driveshaft and is also what makes swapping a big block into a 67-72 a Royal PITA.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 07-03-2002, 11:22 AM   #13
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
I have HEIs in 3 of the four 4X4s I have.. The fourth doesn't have an engine installed yet, but it will have one when it is..... 1 is a 72 K-5 with a BB 402 in the 6 cylender possition... I had to massage the firewall where the valve covers are but that was it. 1 is a 72 SWB 4X4 with 350/4 speed, and the last one is a 72 3/4ton 4X4 with T-350... No problems with clearense on any of them..... If you have your truck lifted so much that the engine, transmission, and transfer case have to be tilted to help with the driveline angles then you will have a problem, otherwise you shouldn't. WES www.ClassicHeartbeat.com
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 07-03-2002, 11:22 AM   #14
68 Stepside
huh?
Hey Mark,
Can you tell me where to get some of that high performance film for my engine? And where should I get a rat that eats plug wires? I need some serious performance mods, so I figured I'd start with those.
TJ
RIP El Jay
Old 07-03-2002, 11:44 AM   #15
Yukon Jack
Yukon Jack's Avatar
68 Stepside - I can get you some of the stuff for your engine, just drop by and we can scrape some from my engine and transplant it to yours. Luckily, my engine will regenerate this stuff ather quickly! However, I'm afraid the rat modifications were done during the prior owner's time with the truck. Maybe someone has a spare goat that could be used to make similar mods.
Glad for all the input on the distributor coming out. I'm kinda thinking about slapping on a new intake and carb since my plans for a new engine are years down the road. Like everyone says in the other posts about the 307's, all that stuff will transfer to a new engine and it would be fun to at least put a little life back into this engine. Heck, with the little itty bitty carb that is on it now (I think it's a one barrel) those changes, along with HEI, will probably be pretty noticable.
Old 07-03-2002, 01:35 PM   #16
Blue68
Blue68's Avatar
Here's mine in a '98 350. Worked fine in my 307 as well. Get the engine to TDC first. And realize you will proabably have to set the distributer one tooth counter-clockwise in order to get the vacuum canister to clear the intake runner. Besides, it makes the cap look straighter.
http://home.comcast.net/~r.landrum/w...tos.html-.html
'68 C-10 LWB, '98 Z-71 350 w/accessories (Serpentine), Edelbrock Performer, Edelbrock 1405 (600cfm) carb, GM HEI, CompCam Extreme 4x4 roller cam, Thorley Headers, Carter Electric Fuel Pump, Vintage Air, 700r4, 3.73, disc brakes and power steering upgrades.
Blue68 is offline   Reply With Quote
Old 07-03-2002, 02:28 PM   #17
junkyardjohn
MINE SURE DID IN SEVERAL TRUCKS. PUT DOWN THE SLEDGHAMMER. STEP AWAY FROM THE HAMMER. YOU CAN PICK UP A GOOD USED GM HEI OUT OF ANY V-8 CHEVY AT YOUR LOCAL BONE YARD FOR ABOUT $30
junkyardjohn
DON'T RENT U-HAUL
Old 07-03-2002, 03:20 PM   #18
Yukon Jack
Yukon Jack's Avatar
While at the junk yard, is there an easy way to know if you are looking at a bad one?
Old 07-03-2002, 04:31 PM   #19
Blue68
Blue68's Avatar
Try to turn it so it will advance. I got a salvage one (used it for a core) that it was rusted so it wouldn't turn for the advance. Pull it and take a look at the gear teeth and check for excess slop. You are going to replace the cap and rotor anyway so don't worry about those items. Other than the visual/physical, there isn't any way to know if the rest is in good shape .
