Old 12-11-2004, 05:35 PM   #1
mocwon
Keep On Truckin'
mocwon's Avatar
Pictures of Vintage Air Super-Gen II mock-up
I was dreading this since it is not the Sure-Fit system but the mock-up was straight forward and went very well. Modified two of the three brackets provided with the kit and welded them in place along with the third stock bracket. Its off to the hose shop next week to have the A/C bead-lock fittings crimped onto the hoses.
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 12-11-2004, 08:01 PM   #2
FuelCellGuy
FUEL CELL GURU
FuelCellGuy's Avatar
As you probably already know, put some witness lines on the crimp collars and the hose so that all the fittings end up pointing the right way. This will prevent twisting the lines for hookup. Clear as mud?? Later, Mark
FuelCellGuy is offline   Reply With Quote
Old 12-11-2004, 08:06 PM   #3
68LSS1
68LSS1's Avatar
That looks good. I was thinking of doing something similar. Are you going to use the stock controls or something different?
Edit: for stock type controls I mean the OEM control plate/unit.
'68 Short Step
LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc
68LSS1 is offline   Reply With Quote
Old 12-11-2004, 08:18 PM   #4
mocwon
Keep On Truckin'
mocwon's Avatar
Mark: yeah I learned the hard way many, many years ago about hose alignment. But, thanks for reminding me.
68LSS1: no, not going stock; see picture below
Just Passin' Thru
Old 12-11-2004, 09:44 PM   #5
68LSS1
68LSS1's Avatar
Oh yeah, I love it. I was trying to keep away from using that control panel because that is going to make me want to shave the dash. But that looks good. I guess I got something else on the to do list. I can't tell by the pictures but could I slide it towards the drivers side some if I did the same thing?
'68 Short Step
Old 12-11-2004, 10:38 PM   #6
mocwon
Keep On Truckin'
mocwon's Avatar
Sure; I started to do just that but decided to center it instead. Just weld up the opening to the right side rather than on both sides and you're done.
Just Passin' Thru
Old 12-12-2004, 02:05 AM   #7
cornutz
All Praise RANDY!!
cornutz's Avatar
A little off subject, but what type of insulating material is that? By the way, looks good, nice fit, and thanks for the pics, I was wondering how that gen II system would work... I want to do the same.
cornutz is offline   Reply With Quote
Old 12-12-2004, 02:48 AM   #8
kxmotox247
kxmotox247's Avatar
Looks good! Show us some more pics when you get further along. How cold will those units blow?
Thanks for sharing the photos.
kxmotox247 is offline   Reply With Quote
Old 12-12-2004, 10:36 AM   #9
mocwon
Keep On Truckin'
mocwon's Avatar
It's a heat and apply Dynomat knock-off that was purchased off E-Bay. $100 for 100 sq. ft. It's very time consuming to apply since it must be heated to activate the backing. I would recommend the stuff with the pressure sensitive, peel and stick backing.
Just Passin' Thru
Old 12-12-2004, 11:13 AM   #10
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Looks like I need to put a couple of more mods on the never ending project truck I seem to own..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 12-13-2004, 12:22 AM   #11
70 net440
Junior Member
70 net440's Avatar
Is the Gen II the one that uses servos instead of vacum pods? Which model are you using? I'm thinking of putting one in the wife's '63 and also in my Coronet.
63 C10
70 Coronet R/T
67 C10
70 Dart Swinger
71 K10
70 net440 is offline   Reply With Quote
Old 12-13-2004, 01:31 PM   #12
junkyardjohn
junkyardjohn's Avatar
Ttt
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 12-13-2004, 04:34 PM   #13
mocwon
Keep On Truckin'
mocwon's Avatar
Yes, it uses servos instead of vacuum pods which also gets rid of the cables with the stock GM system.
I'm using 61005 Series Gen-II Super Cooler with heat, cool & defrost model. It comes with four A/C outlets from the evaporator so I'm probably going to tie two of them together for the center duct or just block one off.
Just Passin' Thru
Old 12-13-2004, 06:56 PM   #14
junkyardjohn
MOCWON .. WHERE DID YOU BUY YOUR KIT FROM & HOW MUCH WAS IT???
JOHN
junkyardjohn
DON'T RENT U-HAUL
Old 12-13-2004, 08:17 PM   #15
mocwon
Keep On Truckin'
mocwon's Avatar
JOHN
Hot Rod Garage
1202 A West Keystone Expressway
Sand Springs, OK 74063
918-241-6333
$1,010.47 including shipping plus the cost of a few fittings and hose adapters for the GM vent balls. I didn't buy the Sanden compressor since I'm using a GM compressor and serpentine setup.
Just Passin' Thru
Old 12-13-2004, 08:47 PM   #16
ol skool 68
turnin wrenches
ol skool 68's Avatar
i was just curious if those vents came with the kit or if yours was an a/c cab to begin with? btw looks like you have done a top notch job there congrats!!
BBB
"three can keep a secret if two are dead" -unknown hell's angel-
D.M.C. -FF-
68 SWB full frame off (project ol skool)
2000 s-10 formally bagged but now my daily driver...
ol skool 68 is offline   Reply With Quote
Old 12-13-2004, 11:12 PM   #17
mocwon
Keep On Truckin'
mocwon's Avatar
BBB
Thanks.
It was a non-AC cab that I converted to an AC cab by cutting the holes. The vents were included in the price.
Just Passin' Thru
