Old 12-13-2004, 10:26 PM   #1
dinnut
dinnut's Avatar
motor mount question
this is a smallblock 350. on a 1970. i know the top part of the motor mounts bolts to the frame with 2 bolts. is the bottom part, that touches the crossmember supposed to be bolted down to the crossmember part? mine are not and it seems like my shifter moves alot and i was wondering if this would cause this...
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 12-13-2004, 10:27 PM   #2
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
not a pro but i think that there is one bolt that holds them to the saddle of the crossmember
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 12-13-2004, 10:28 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
It's a 3/8 bolt with a nut underneath the bottom of the crossmember. The nut's hard to get to, is probably why they left it out.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 12-13-2004, 10:37 PM   #4
dinnut
dinnut's Avatar
does it make a difference? like will it not move around as much if i put these bolts in?
70 longbed
496/th400/Ford 9"
Old 12-13-2004, 10:38 PM   #5
Tx Firefighter
That's why GM put the bottom bolts there.
Old 12-13-2004, 10:43 PM   #6
dinnut
dinnut's Avatar
thank you! ill have to get to work on these to get them lined up
70 longbed
496/th400/Ford 9"
