Old 07-03-2002, 02:55 PM   #1
dubie
dubie's Avatar
took the heads off...look what I found
A bit of rust in one of the cylinders. I put the penetrating oil to it and it took it right off. Just have to use a 400 grit emery to remove a bit off the marking now.
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 07-03-2002, 03:19 PM   #2
Yukon Jack
Yukon Jack's Avatar
Was it just a gasket problem or is something worse wrong causing that problem?
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 07-03-2002, 03:25 PM   #3
dubie
dubie's Avatar
Looks like it was a gasket problem. Whoever did the work on this engine previously did a really bad job. So it looks like it's time for more of a rebuild than i was hoping.
Old 07-03-2002, 04:38 PM   #4
mikej71
Unregistered User
mikej71's Avatar
How long has it been since it was rebuilt? It sure is clean.
Mine had crap built up almost to the bottom of the intake.
71 SWB Stepside
SB400/TH350
mikej71 is offline   Reply With Quote
Old 07-03-2002, 05:59 PM   #5
DennyB
Led Sled! Discs R 4 ME!
DennyB's Avatar
Do yourself a favor dubie, and get the block and heads magnafluxed (sp?) before the rebuild
Doesn’t look to bad though unless a crack in the block or head caused the water seepage into the cylinder.
"Never ride faster than your Angel can fly"
I.M.O.M,W,J&C
Patriot Guard Rider
DennyB is offline   Reply With Quote
Old 07-03-2002, 06:12 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
That does not look right...
Old 07-03-2002, 06:39 PM   #7
DennyB
DennyB's Avatar
BTW, Are those "pits" in the top of the #2 piston?
I.M.O.M,W,J&C
Patriot Guard Rider
Old 07-04-2002, 09:36 AM   #8
dubie
dubie's Avatar
No those aren't pits. It's just the pic. I will be taking the block to the local machine shop to have the cylinders honed and re cross hatched, might even go as far as going .40 over, dunno yet, gotta see how much $$$$ it's gonna run me. But it looks like this is gonna be a winter rebuild project. I was hoping to have it done this summer, but looks like it's postponed for 1 more year.
Old 07-06-2002, 05:40 PM   #9
Fast68Chevy
Fast68Chevy's Avatar
was the gasket steel or composite? if was steel then was probably original. if composite using no sealer then has been replaced
what heads casting number were on there ? date code ?
Fast68Chevy is offline   Reply With Quote
